exterior teak - SailNet Community
post #1 of 4 Old 09-04-2001 Thread Starter
exterior teak
Does anyone have a good method of removing Cetol from exterior teak handrails and toerails?
jjjulius is offline
post #2 of 4 Old 09-06-2001
exterior teak
I use a pressure washer being careful not to use more pressure than neeeded........Too much pressure will remove some of the soft teak..........Areas that cetal is not easily removed should be removed using a second pressure washing.....Let the wood dry before the second washing.
randall2v is offline
post #3 of 4 Old 09-06-2001
Senior Nappy Headed Ho
exterior teak
I too will be starting over with new Cetol next spring on the toe rails, grab rails, drop boards etc. However, a pressure wash sounds like a very bad idea. You will most likely end up eroding the soft grain of the wood by using this technique and require a major sanding operation to make the wood ready for another application of Cetol or varnish. There must be a more controlled and precise way of removing this stuff without the "Bigger Hammer" approach of "sand blasting" it off. Some other ideas out there?
Denr is offline
post #4 of 4 Old 09-06-2001
exterior teak
I agree that pressure washing is a very bad idea. Basically you have a few choices; each has its ups and downs. Cetol is tough stuff. 1. Sand it off. 2. Use a heat gun and scrape it off. 3. Use a chemical stripper. As evidenced by what the pros do, sanding is best. Heat guns can drive substances into the wood and chemicals can damage wood and the gelcote. Good luck.
hamiam is offline
