Old 08-09-2006
oday27's Avatar
Coming to a dock near you
oday27 is on a distinguished road
Question cabin cushion replacement
I need new cabin cushions for my Oday 27'. I have found some fabrics that I like that should cost me under $100.... however I am having some issues finding seat cushion material. I am not sure how thick/quality of the foam I need. Obviously the foam wouldnt get as much use as a bus seat so I am not looking for quite as much "durability" also I dont want to break the budget.
anyone have any information it would be much appreciated, Thanks
-Tony
1986 J-22 SHIPFACED
1975 O'day 27' got O'vertime?
NASCAR FAN
Old 08-09-2006
ASA and PSIA Instructor
A first quality cushion should be 5", 4" is probably typical, maybe less on real budget boats. A professional glues a layer of spuncotton to the foam for a soft feel and shape. I am not sure of the foam spec.
I suspect that if you don'tuse the proper quality of foam that it will be immediatley apparent when you first sit on the new cushions. The materials for this stuff is probably 30% or less, of the cost of having them made. You should get the best, especially if you are saving labor by doing it yourself.
IMHO it is good boat dollars to have cushions professionally done.
Old 08-09-2006
camaraderie's Avatar
moderate?
Use 4" cushions wrapped in dacron. Try various compression ratios out IN THE SAME THICKNESS before deciding what to buy. 20/40 is fairly typical for seating...but too hard for bedding for most people. If you don't use the Dacron wrap you nee to cut the cushions a bit larger than the covers in order to get them to fill out.
Old 08-09-2006
If you're going to make the cushions yourself, you probably should look to get the foam from a foam distributor, rather than a marine supplier, as the cost will be much lower. You either need a good closed cell foam—for stiffer cushions, or a very open cell foam for softer cushions. Cutting the foam to shape is very easy if you freeze it and use an electric carving knife to cut it.
Freezing it makes it stiffer, and the electric carving knife cuts through it quite easily, allowing you to cut curves as well as straight lines.
Cabin Step Mast JNBDeVore Gear & Maintenance 6 10-03-2007 12:35 PM
Cabin top winch mounting boards larsfis Gear & Maintenance 1 03-03-2003 05:10 PM
Cabin Cushion Covers -- Annapolis billkidd Gear & Maintenance 2 09-01-2002 04:03 AM
Cruising Advice Needed!!! 2 or 3 cabin for 3 single guys? robbieturner Cruising & Liveaboard Forum 5 10-17-2001 05:26 AM
Replacement curtains donato Gear & Maintenance 1 06-29-2001 07:52 AM
