self tending jib - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 08-11-2006
dm567 is an unknown quantity at this point
self tending jib
How do you ad a self tending jib to a sailboat like the beneteau 331?
I am aware that it will hinder performance.
Dom
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 08-11-2006
Actually, I do remember reading about a self tending jib without a boom that could be furled when not in use. How does one go about that?
So I'll revise my question. Whats the best way to intall a self tending jib with a boom and without a boom with furler?
Thanks,
  #3
Old 08-11-2006
Depends on what you're trying to do. To setup a self-tending jib, with a furler, you can often install a jib traveler track, and then have the jib attached to a single sheet, that goes through a block on the traveler. A setup like this is used on the Solings that have self-tending jibs.
Installing a self tending jib with a boom is probably more work and effort, for not a lot of return. The traveler you'd need to setup for the boom is pretty much the same as the one you'd setup for the rig above.
The real problem I see you running into, is that all of the "self-tending" jib rigs are limited to jibs that fit within the foretriangle. If your boat is one that needs a bigger headsail for better performance, then you're not going to be happy with the results. IMHO, not a lot of point to installing a furling mechanism for a headsail that is on ly 100% of the foretriangle.
You may post attachments
You may edit your posts
Adding jib sail mikeact41 Learning to Sail 5 08-16-2008 11:36 AM
Attaching Sheet to Jib wigwam Learning to Sail 10 10-04-2003 06:29 AM
dousing a hanked jib terryny Seamanship & Navigation 17 01-16-2003 06:19 AM
Venture 24 self tending jib HELP popeye S General Discussion (sailing related) 2 06-06-2002 05:17 PM
need to raise the Jib. glowworm Gear & Maintenance 4 04-10-2001 12:46 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
