Simple small boat jib down haul? - SailNet Community
 1Likes
  • 1 Post By krisscross
post #1 of 9 Old 08-10-2015 Thread Starter
I have a Hurley Silhouette sailboat. First boat. Looking to learn. A jib downhaul would really help my single handing. I thought this might be a good first rigging job for a newbie. How do I do it?
I don't need to run anything to the cockpit. The boat is only 18 feet and I do my sail handling at the mast by stepping into the boat and standing at the mast. So I think I can just rig it to the jib and need it run to the mast right where my jib and main halyards are cleated.
Need to use the KISS method with this guy.
greggyN is offline
post #2 of 9 Old 08-10-2015
krisscross's Avatar
Re: Simple small boat jib down haul?
Very simple. Attach a block to the bottom of your forestay and run the line from top of the jib through it into cockpit. Keep it taut or it will get tangled when tacking.
LinekinBayCD likes this.
Plato
krisscross is online now
post #3 of 9 Old 08-10-2015 Thread Starter
So from the top of the jib through the block and back to the mast (which is practically the cockpit in my boat!). What is the best method/location to attach the downhaul? Weave it through the hanks? Attach it with a bowline to the same grommet as the halyard?
greggyN is offline
post #4 of 9 Old 08-10-2015
On my 22' Starwind I just attached it with a bowline to the same grommet as the halyard. I don't weave it through the hanks, I just let it fly. I attached the block onto the turnbuckle that attaches the jib to the forward chainplate. It's so cool how something so tiny can make such a huge difference. I sailed the boat for a couple of years without it and laughed out loud the first time I pulled the jib down without going forward
1984 Starwind 22
"Julianne"
WheresTheBrakes is offline
The Following User Says Thank You to WheresTheBrakes For This Useful Post:
greggyN (08-10-2015)
post #5 of 9 Old 08-10-2015
Remember you're a womble
PaulinVictoria's Avatar
On my old 24' I wove it between the hanks to stop it flying loose in the breeze. Also, tie it to the last hank and not the head of the sail, it can cause the head of the sail to twist and jam up when you pull on it, whereas pulling from below it works all the time.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
The Following User Says Thank You to PaulinVictoria For This Useful Post:
post #6 of 9 Old 08-11-2015
I don't discuss my member
zz4gta's Avatar
I would tie it to the top hank or one or two down from the top. The 2-3' of sail that's still up doesn't catch much wind, and as PV said, it keeps it from getting jammed.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #7 of 9 Old 08-11-2015
asdf38's Avatar
And where do people bring it back too?
One of the advantages of no furler is having no lines running around the deck. I have some interest in trying this but have a hard time picturing where it would run.
asdf38 is offline
post #8 of 9 Old 08-12-2015
Mine was run back the cockpit, along with all halyards, the whole point of it was so that I didn't have to leave the cockpit if things got a little snorty - get close hauled, back the jib to get it over the deck, leave the sheet tight, pop the halyard and pull the downhaul to get the jib on deck and under control safely and quickly.
Orange Crush
1974 C&C27 MkII
post #9 of 9 Old 08-12-2015
krisscross's Avatar
I usually cleat that downhaul line on the same cleat my jib uphaul line is on.
Plato
Ideas for a small, simple, offshore, family cruiser....... Brenme262 Cruising & Liveaboard Forum 23 04-11-2015 02:55 PM
Jib halyard shackle too small for jib's head matthewwhill General Discussion (sailing related) 14 05-23-2014 08:15 PM
Small main sail, large jib - questions matthewwhill Boat Review and Purchase Forum 58 12-28-2012 03:05 PM
Simple 15A Shore Power In Small Boat (Looking to install in-line 15A AC Breaker) ns22simple Electrical Systems 14 11-30-2012 02:01 PM
A Simple Cruise on a Simple Boat Jim H Cruising & Liveaboard Forum 4 06-20-2011 05:10 PM
