which wire rope for hand press fittings / standing rig - SailNet Community
post #1 of 7 Old 08-13-2006 Thread Starter
Hello, I've always had 7x19 3/32 rigging on my albacore. I like doing my own nicro press so I can repair and adjust easily. The downside is the wire always frays around the thimble. Would 1x19 be better for this application?
Also considering going to 1/8 .. comments welcome.
gjxj is offline
post #2 of 7 Old 08-14-2006
The construction of wire rope is described as X by Y, where X is the number of wires in each strand, and Y is the number of strands in the rope. Three are commonly used in stainless steel standing rigging:
1 x 19 - size for size the strongest simple wire you can get, and by far the most common for standing rigging. It does not like being bent, so is not suitable for running rigging, nor for use with a thimble.
7 x 19 - less strong than 1 x 19, but much more flexible.
7 x 7 - middling in terms of strength and flexibility.
GordMay is offline
post #3 of 7 Old 08-14-2006 Thread Starter
Too stiff to go around a thimble - thats exactly what I wanted to know.
Can 7x7 work with a thimble?
Thanks.
gjxj is offline
post #4 of 7 Old 08-14-2006
Moderator
Jeff_H's Avatar
Are you asking about standing or running rigging? 1 x 19 would be ideal for standing rigging on boat the size of an Albacore, even if you are putting it on a thimble.
Jeff_H is online now
post #5 of 7 Old 08-15-2006
Heavens, I'd be very careful about using 1x19 with Nicropress. Getting that very stiff wire around a thimble will definately unlay it. You'll lose bearing surface and the whole thing will be a bit of a mess.
If you must use 1x19, either get it machine swaged or use StaLok or Hayn mechanical fittings, otherwise if the strength is there 7x7 or 7x19 can be Nicropressed, but be very careful about the strength.
Hugs,
SoK
SteppingonKittens is offline
post #6 of 7 Old 08-15-2006
General article on avoiding rig failure
http://www.oceanpix.co.uk/Yacht-main...g-failures.htm
infonote is offline
post #7 of 7 Old 08-16-2006
You really should talk to a rigger. Oh wait, I am a rigger.
3/32" 1x19 is fine to use with nico-press fittings. Double sleeve them for safety and to cover the end which you will need to pull the wire around tight around the thimbles. If you want, use a thimble one size larger than the wire size. That makes it easier on the wire. But honestly 3/32" or even 1/8" won't be a problem. Your wire won't unlay unless it's defective.
Bottom line, 1x19 will make a much better standing rig than 7x7 or 7x19.
knothead is offline
Cutter rig vs. sloop rig Akacake Boat Review and Purchase Forum 21 03-06-2016 09:48 PM
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 08:30 AM
Wire or Rope Luff davejean General Discussion (sailing related) 1 11-08-2003 06:41 AM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 04:10 PM
Need stainless wire recommendation... jack_patricia Gear & Maintenance 1 06-25-2001 07:16 PM
