  #21 (permalink)
Old 06-24-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
I've installed a ST30 in my Santana525 and a ST60 in the Cal 9.2. Both are epoxied to the inside of the hull and read to the max depth of the lake. While sailing on a Cal 2-30 in the SF Bay, it also had an older flasher style depth system with the puck glued to the inside of the hull. You can use water, grease, etc to couple the transducer to the inside of the hull to verify the sensitivity/ reliability of the system prior to committing to gluing it in place.
Cal 9.2 #19 SilverSwan
  #22 (permalink)
Old 06-24-2009
scottyt is on a distinguished road
i did a replacement on an older system on an IP and just used 4200, works fine
my boat has a fish finder and i used gel coat paste, and waxed the transducer first in case i ever need to get it loose
Depth Sounder Tranducer chuckg Gear & Maintenance 10 02-01-2010 02:51 AM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Hull speed and wide sterns Jeff_H Boat Review and Purchase Forum 24 11-21-2006 11:58 PM
Transducers and depth sounder High teck obiec Gear & Maintenance 3 11-08-2003 03:47 PM
depth sounder dillemna chuckg Gear & Maintenance 6 11-12-2001 07:53 AM
