Old boat deck flex - SailNet Community
post #1 of 4 Old 09-06-2001 Thread Starter
cmj
Old boat deck flex
Hi all,
I''ve been offered an 18 yr old 26'' fibreglass racer, and certain areas of the deck nr the cockpit and chainplates flex when I step on them. There are no visible cracks or weird noises, and while I don''t want to look a gift horse in the mouth, I''d like to know how significant a problem this is likely to be. Any thoughts, anyone?
cmj is offline
post #2 of 4 Old 09-07-2001
Old boat deck flex
Methinks core rot. Can be difficult/time consuming to fix. Might want to get a surveyor with a moisture meter to check it out.
hamiam is offline
post #3 of 4 Old 09-09-2001
Old boat deck flex
Go to WEST MARINE and get a free copy of the WEST SYSTEM fiberglass repair manual. It will answer all of your questions concerning delamination and its cure.
Some repairs are easy and straight forward if you are handy,ie drilling holes in the area and using a vacuum to suck out the water and injecting epoxy, some more complex as in cutting out the inside area and replacing it with plywood and glassing over.
It''s all covered in plain english and you should be able to determine if it is something you want to tackle.
Don''t let a good boat go because of a little work... Good luck..JEF
JEFryar is offline
post #4 of 4 Old 09-11-2001
Old boat deck flex
If you see no cracks or holes in the deck, it should not be rot, its probably just not a strong deck. Its easy to fix. make access to the underside of the deck where it flexs, sand it back, cut some hose in half ( normal garden hose ) and glass it in place under he deck. You will probably need to do at least 3 times about 1 foot apart. Use at least 4 layers of glass ( woven ) and use epoxy resin. It is really easy, i had no fiberglasing experience, but after working on my own fiberglass boat, it becomes second nature. Look up some books by Don Casey..
seawolf1 is offline
New name (I know, I know) owlmtn Boat Review and Purchase Forum 13 12-13-2009 07:46 PM
help with lifes dream kimby Boat Review and Purchase Forum 37 12-02-2009 11:32 PM
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
boat purchase, taxes, residence -- help for NW sailer? winslow59 Boat Review and Purchase Forum 15 01-14-2007 10:20 PM
What makes a good family cruiser boat? tziehm herSailNet 16 08-04-2006 06:45 PM
