Old 08-15-2006
rcibul is on a distinguished road
Cabin Carpet
My new (to me...) 1996 C28 mkII has outdoor grade carpet in the cabin that is pretty worn, and the rubber backing is turning to dust. I like the idea of carpet and was wondering if there is a source of cut & bound carpet for Catalina sailboats, or if the best approach is to just buy some carpet and figure out the cutting/binding. I can use the existing carpet as a pattern if that is the case, but the edge binding might be a pain..
Any suggestions on vendors/techniques for replacing the carpet?
Thanks...
-Bob C.
  #2
Old 08-15-2006
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
If the present carpet is good enough for a pattern, you should be able to have it done at a carpet shop. Or, buy the carpet and cut it out and take it in for the edging.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
  #3
Old 08-15-2006
douggiestyle is on a distinguished road
i own a carpet store.
if you can use the old as a pattern it would be best.
i would suggest an outdor carpet. there are many that will look like indoor carpet. or you could use a high quality commercial that is solution dyed. polypropolene (olefin) are most common for outdoor, while solution dyed nylon is most common for high performance commercial. most polypropolene rugs are solution dyed.
the foam backing can always be added on by a good shop. so dont look for only foam backed carpet you will limit your choices. i would suggest that you take the old carpet to the dealer and let them do the cutting and binding. i would also suggest that you insist on having the edges sealed (using hot glue) after cutting but before binding. this will eliminate strays which could run.
  #4
Old 08-15-2006
Thanks for the carpet advice.. I am off the the carpet shop with my old carpet template to talk those guys into cutting, sealing, and binding some primo new outdoor carpet!
-Bob C.
  #5
Old 08-15-2006
Jeff_H's Avatar
Administrator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
Another great source is companies that supply remnants of OEM Automotive carpet.
You may post attachments
You may edit your posts
Carpet in the cabin wintermute11 Gear & Maintenance 14 01-16-2009 11:01 AM
Cabin Step Mast JNBDeVore Gear & Maintenance 6 10-03-2007 12:35 PM
Open Cabin -- August BVI Charter Kathie_WE Chartering 0 06-15-2003 05:08 PM
Cabin top winch mounting boards larsfis Gear & Maintenance 1 03-03-2003 05:10 PM
Cruising Advice Needed!!! 2 or 3 cabin for 3 single guys? robbieturner Cruising & Liveaboard Forum 5 10-17-2001 05:26 AM
SEO by vBSEO 3.6.1
