Blogs
User Name
Old 08-15-2006
jknappsax jknappsax is offline
jknappsax is on a distinguished road
Removing wallcovering adhesive
I just bought a 1978 O'Day 32' center-cockpit from an elderly widow (her husband passed away last October), and there has been water leaking in around the mast for quite a while. The bilge was very moldy, which I've cleaned up, and most of the foam-backed fabric wall covering needed to be removed due to the mold and mildew. I was hoping that someone here might be able to recommend some method (other than sanding) that will remove the old adhesive and deteriorated foam, but not damage the raw fiberglass underneath. I plan on painting the surfaces, so any advice for prepping and priming the surface once I get the mess off would be great. And of course, I'll Spartite the mast to keep this from happening again. Any advice or suggestions would be greatly appreciated. TIA.
Old 08-15-2006
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
There are some very good adhesive removers that should be fiberglass safe... Since the foam is porous, it should remove the foam at the same time. Try this page: http://www.kleanstrip.com/removers.htm
If you're new to the Sailnet Forums... please read this POST.
Old 08-16-2006
Thanks
Thanks much for the recommendation; I'm checking out their products online now.
Sponsored Ad
Old 08-16-2006
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
jk-
Depending on the adhesive they used...some of them are designed to strip easily if you hit them with steam (like a wall paper steamer) while others are extremely hard to remove. The 'citrus' type solvents may be your best bet, they are slower but working in an enclosed hull, any other solvent may be dangerous to breath. The strippers that are sold with a special paper (apply goo, cover with paper, come back next day to peel away the whole thing) may be your best bet for this.
Old 08-16-2006
NickL's Avatar
NickL NickL is offline
NickL is on a distinguished road
Originally Posted by hellosailor
jThe strippers that are sold with a special paper (apply goo, cover with paper, come back next day to peel away the whole thing) may be your best bet for this.
Have you used this on paint? I looked at some the other day at west marine
it sounds great, but is it really worth it? or do i just need to get out the in the heat of the day some good old 36grit and the orbital?
Old 08-19-2006
BTW, the resins used in fiberglass are fairly similar to those used in paints and some adhesives, so it is probably a good idea to check with the manufacturer of any solvent you plan on using as to whether it is safe for the fiberglass on your boat.
Old 08-20-2006
TalbotUK TalbotUK is offline
TalbotUK is on a distinguished road
I suspect that you are referring to a rubberised adhesive, like contact adhesive (i.e. spread on both surfaces, and when they come together after drying until tacky, even if they are misaligned - thats where they are staying!).
I had to remove this from my boat in order to replace the headlining. My local boat fabric shop sells a flap sanding wheel that fits on a drill that is designed for the removal of this adhesive, but the best way I found to do it was using a cup brass wire brush in a small angle driver, preferably not running at the highest speeds that some of these can run at. It is a very messy job, but providing you dont try to do too much at a time, the brass wire flicks the solid adhesive off the grp and it can then be hoovered up. If you try to do too much at once, it will melt the adhesive and make it difficult to remove, use too much force and it will start to wear a hole in the grp.
You must wear eye protection, full body coverage, and a really good mask
Old 08-21-2006
resdog's Avatar
resdog resdog is offline
resdog is on a distinguished road
Good to know as I have to do the same job on my Beneteau. I was thinking about painting the interior with either Bilgecoat or Zolatone instead of installing more of the vinyl/foam headliner material.
Old 08-30-2006
Painting raw fiberglass
Yeah, that's what I'm thinking of using, too. I read about a ceramic additive that will give paint some insulating and soundproofing qualities.
Old 08-30-2006
resdog's Avatar
That sounds like the coating that was on my brother's Santana 20. It was thick, almost like a skin coat of plaster. It was flaking off when he bought it and was a mess to remove. I don't remember if he found anything like it to replace the old stuff.
Display Modes
vB code is On
Removing 5200 Stormer Gear & Maintenance 8 08-26-2006 12:22 AM
removing old silicone caulking bmcald Gear & Maintenance 3 03-20-2003 05:26 AM
options for removing VC-Tar BeneteauMark Gear & Maintenance 3 02-27-2003 05:11 PM
Removing antifouling paint Badfish Gear & Maintenance 12 01-04-2001 04:46 AM
removing sail numbers sedavis General Discussion (sailing related) 5 12-20-2000 06:03 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
