How to remove seacock without resorting to C-4 - SailNet Community
 4Likes
post #1 of 12 Old 08-22-2015 Thread Starter
We have five unused thruhulls, and the seacocks have come out of four of them with no problem. The fifth one is hanging tough. The other four didn't have backing plates, but this one does. It appears not to have been originally installed when the boat was made (1977 B29.9). It went to the manual overboard pumpout.
Mr. cthoops has already used the Dremel to get rid of the mushroom head on the thru hull. He thought it might be bolted through the hull from the inside, but after sanding down to the gelcoat he can't find any sign of a bolt. He's tried whacking on it with a hammer and it's not budging. Maybe it was installed with 5200?
We've thought about trying wire with dowels on either end to saw along the bottom of the seacock, and will give that a try tomorrow unless there are other, better options. Besides the C-4 of course.
Any suggestions?
zeehag likes this.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #2 of 12 Old 08-22-2015
Matt's Avatar
Re: How to remove seacock without resorting to C-4
if it comes down to it. if its a bronze connector you can heat it up very quickly then cool it and put pressure. the trick is to separate the thru hull from the adhesive material but cooling the fitting down before it has a chance to damage the gelcoat/fibreglass . it could take 3 to 100 tries, if you get it on the first try the fitting was probably too hot. this is the last resort though and it will definately work. hopefully others have suggestions that will work before you have to resort to this
Matt is offline
post #3 of 12 Old 08-22-2015
Have you tried a Thru Hull Wrench? Sometimes torquing them can help break them free. If it is a smooth bore you can try a large cammed pipe extractor for a plumbing supply place to get a grip on the inside of the fitting.
Otherwise, heat, banging, worst case you can cut it out with a hole saw.
Greg
Stumble is offline
post #4 of 12 Old 08-23-2015
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
Det cord - easier to control. Wrap around thru hull - zap, its gone!
CVAT likes this.
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #5 of 12 Old 08-23-2015
CVAT's Avatar
You could always try some Fe2O3(Iron Oxide; i.e. rust) + 2 Al(aluminum) → 2 Fe(iron) + Al2O3(aluminum oxide) + a whole lot of heat, if your into chemistry, also know as thermite. This will produce enough heat to remove the seacock and anything else around it.... JK
Use your head for something other than a hat rest.
CVAT is offline
post #6 of 12 Old 08-23-2015
Lake Superior Sailor's Avatar
Drive in a wood plug, for centering hole then use a hole saw......Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #7 of 12 Old 08-23-2015
snake charmer, cat herder
zeehag's Avatar
i personally like the c4 idea.....
i replaced a thru hull in water when i first got my ericson in 2004.. it was a 1979 installed seeping wonder. it is a wonder that it didnt go away soooner. the nightmare collection of successive bandaid repairs was scary enough.
when i had it done it took a handfull of c4, 4 men and 2 plungers. was the redefinition of worst case scenario.
would i repeat--hell yeah, as it was done professionally and was much less money out than haul and repair.
goood luck.
make sure you have the folks standing by, if you are in water. if out of water..have a great time. it was installed by neptune.
formosa 41, cruising tropics
zeehag is offline
post #8 of 12 Old 08-23-2015
jsaronson's Avatar
use a sawzall to cut the bronze in several places. Get some un-5200 or use gas to dissolve the 5200.
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #9 of 12 Old 08-23-2015
Can you get a sawz-all blade inside the thru hull? If so, cut a few lines, so the fitting is in sections and try to pry the sections out. Sort of like the method to remove a cutlass bearing.
Jeanneau 54DS
Minnewaska is offline
post #10 of 12 Old 08-23-2015
Over Hill Sailing Club
smurphny's Avatar
If you are just going to glass in the hole, the suggestion by LS Sailor is probably the way to go. Just drill it out with a hole saw. When glassing over, make sure to feather out plenty far. I've seen these kinds of repairs done very poorly, inviting a 2" hole to open up in the hull if slammed with a wave.
smurphny is offline
Can you ID this seacock? jsaronson Gear & Maintenance 15 01-26-2014 08:23 PM
seacock? redhead78 Diesel 2 01-30-2010 07:59 PM
seacock redhead78 Gear & Maintenance 5 01-19-2010 09:44 AM
seacock seized bluwateronly Gear & Maintenance 13 07-09-2008 08:23 PM
do i need to remove rudder to remove shaft 37cc jumpnkd Irwin 4 04-13-2008 10:48 AM
