Old 10-21-2006
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
Joey, if you are going to solder the wires, adding a sloppily smashed crimp to the mix is just screwing around. It serves no purpose except to waste time and money and encourage the joint to fail by adding the weight of the crimp to it.
Better to just twist the wires together and solder them, then cover them over. Faster, cheaper, simpler, more reliable.
And while you can twist wires by hand, a lineman's dyke (plier) is the tool actually designed to do that.
  #62
Old 07-25-2009
Mechsmith
Mechsmith is on a distinguished road
I always use some form of corrosion inhibiter on all crimped joints. Silicon dielectric compound seems to work well. My personal preference is for the commercial "Anti Seize", availiable at any auto parts store. Supposed to be good for 50 years in salt water. Stick the wire into it first then crimp. Electricians also use a similar compound when dealing with aluminum wire.
In some 25 years of experience I can say that the "Anti Seize" has never failed. No joint protected by it has ever failed, whether it be electrical or mechanical.
  #63
Old 07-26-2009
scottyt is on a distinguished road
well i use crimps and solder but i am weird. i use solder for big wires, as i dont have big crimpers. what i do heat the ring and fill it with solder, then i slightly tin the wire, just enough to get some flux on the wire, then i dip the wire into the hot solder and as soon as i see it penetrate the wire i take away the heat. then i use adhesive lined heat shrink to seal.
edit i have done big connections like this for 10 years, granted never on boats till a year or so ago. i have never had one fail, including on some pretty serious off road trucks that get plenty of vibration.
for small wire i use standard anchor crimps, not heat shrink ones. then i fill the ends of the crimps with liquid electric tape, let it dry, then apply another coat until i cant see the crimp anymore. i also coat the end of the sheath with the liquid tape to stop it from getting any moisture up inside the sheath
  #64
Old 07-26-2009
irwin325cc's Avatar
irwin325cc is on a distinguished road
I am in agreement with what dave.verry said. As a HVAC man I deal with wire connecters all the time and the worst tool you can use would be the very thin crimper/stripper you get at the hardware stores as those do a worse job than just a pair of needle nose pliers in my opinion. The ratchet type are good, I use a set that electricans use they look like a pair of dykes but have several diffrent crimp slots for diffrent sized wires/connectors and are like a 1/4" or more thick instead of those cheap ones that are like 1/8".
Adhesive shrink tape is a must also. Electric tape is a huge no no in the engine area as the heat and fumes will make nothing but an unraveling mess.
Has anyone tryed using the liquid electric tape? I'm curious as to how well/messy it is.
  #65
Old 07-26-2009
i just posted that i use it. it is messy if your not careful, but you can use the messy side of it to make sure you got everything covered. be prepared to wipe up the sticky little drip strings that will happen. just dont put it on too thick it will take too long to dry, multiple thin coats is the trick to it. takes longer than heat shrink, but i think its better at sealing, esp if you dont use adhesive lined heat shrink.
now heat shrink is better for physical protection but the plastic on the crimp is even better. in the long run i would say there is no difference in quality or longevity of a liquid tape or adhesive lined heat shrink. its what makes you feel better
  #66
Old 07-26-2009
mitiempo's Avatar
Jeez, I thought this subject was finished. It makes an argument about religion seem tame.
Excellent tutorial on wire termination with pictures so jorjo can understand by Mainesail All About Marine Wire Termination Photo Gallery by Maine Sailing at pbase.com
Making battery cables also by Mainesail Making Your Own Battery Cables Photo Gallery by Maine Sailing at pbase.com
Wire size calculator - thanks Mainesail AWG by wire length/amps calculator
ABYC - segment of standards with wire ampacity table at bottom ABYC Wiring Standards
Link to a looong Sailnet thread on this very subject for those of you who would like to read more on this subject Crimping versus Soldering
Brian
  #67
Old 10-09-2012
fishermanjoe1 is on a distinguished road
Re: Advice, please on crimping wire connections...
Hey guys, what do you think is the best quality crimper... Im in the market and I would like to get a very good quality crimper for heat shrink connections... I pretty much just use heat shrink connectors... Thanks for any input
  #68
Old 10-09-2012
LinekinBayCD is on a distinguished road
Its all in this thread and the links.
You may post attachments
You may edit your posts
Boat buying advice for 35''+ range jmshack Boat Review and Purchase Forum 36 12-31-2006 11:53 AM
Handheld Radio advice Needed natejount Learning to Sail 9 06-25-2003 08:23 AM
Anchor Chain vs Dog Wire jb2of3 Gear & Maintenance 1 04-27-2003 04:13 AM
Shore power problem! Burned ground wire at main breaker JohnDrake Gear & Maintenance 2 08-20-2002 05:08 AM
Need stainless wire recommendation... jack_patricia Gear & Maintenance 1 06-25-2001 07:16 PM
SEO by vBSEO 3.6.1
