Electronic Chart Plotter - SailNet Community
post #1 of 6 Old 08-23-2006 Thread Starter
Any one know if it is possible to reconfigure a Furuno Plotter form C-Map to Navionics?
SledDog is offline
post #2 of 6 Old 08-23-2006
It would help if you said what model Furuno ChartPlotter...they probably make quite a few models now...and some of them probably can use both Navionics and C-Map, and others can't. In any case, you should probably check with Furuno's tech support over on their website.
sailingdog is offline
post #3 of 6 Old 08-23-2006 Thread Starter
Good point. It's an 1833. I have had zero luck with Furuno tech suppport They have declined to answer three emails (from 3 accounts lest it was a server issue).
SledDog is offline
post #4 of 6 Old 08-23-2006
According to the Furuno site.
Utilizes Furuno CDC or Navionics® mini chart cards
So if you need C-Map support, I think you're RTF or SOL.
post #5 of 6 Old 08-23-2006
Surfesq's Avatar
You can absolutely use Navionics with Furono Chart Plotters. That's what I use and they are terrific. Good luck.
Surfesq is offline
post #6 of 6 Old 08-23-2006
The Panbo marine Electronics Blog had found a few problems with a ledge not being on all of the electronic charts. It was Navionics that was missing a critical ledge on their version of the charts.
Brass Pelican Chart Markers? Cap'nJeff Gear & Maintenance 2 06-27-2006 08:14 AM
Yeoman Paper Chart Plotter inadee Gear & Maintenance 0 05-08-2002 12:32 AM
Chart Plotter Installation rpowell Gear & Maintenance 3 12-31-2001 06:29 AM
CHART PLOTTERS SHIMSHON Gear & Maintenance 0 12-04-2001 07:23 AM
CHART PLOTTERS SHIMSHON General Discussion (sailing related) 6 02-27-2001 07:54 AM
