08-24-2006
Sounds like you're doing the right thing with removing the core, filling the fastener holes with thickened epoxy and the like. I don't know if I'd go and epoxy anything hardware in place though. However, epoxying the bolts in place, after coating them with a suitable release coating, is a good way to get additional strength to the fixture.
I wouldn't use the epoxy and graphite, as the black gaps are filled with caulk, which is supposed to expand and contract with the teak, as the temperature changes. Epoxy will not be able to do that.
Epoxying the wood to seal it is a good idea, but you have to make sure that the epoxy coating is complete, without any flaws, as any flaws will allow moisture into the wood. There are some thinner, lower viscosity epoxy resins that are primarily designed for sealing wood.
