Wiring an Aqualarm - SailNet Community
post #1 of 7 Old 10-16-2015 Thread Starter
Master Mariner
capta's Avatar
Wiring an Aqualarm
At us$60.00 an impeller and an hour to an hour and a half to remove and replace the pump with a new impeller, I'd really like to limit this to a yearly maintenance issue, not a lack of water caused necessity.
Enter the new to me item; Aqualarm cooling water flow detector. About time! Brilliant, why did it take so long for this one to get on the market and why doesn't every water cooled engine have one???????
So, the question is can this normally open switch be used with an Onan fuel solenoid to immediately shut down the unit automatically, if the cooling water stops? As the pump is direct drive, I assume it begins pumping immediately when the engine is cranking over, which would close the switch, allowing the generator to start or would it interfere with the fuel solenoid during start up?
If it would allow the generator to start, I assume I would just break the solenoid positive side wiring and add this switch, like a bilge pump auto switch.
I'm really not interested in running an alarm, as the time it would take to shut down the gene would probably cost me the impeller anyway.
Any thoughts?
I will alarm the ME though, because I have a cockpit shutdown on that.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #2 of 7 Old 10-17-2015
Re: Wiring an Aqualarm
I would prefer an alarm, which would allow for plenty of time to shut down, before damage occurs. Even if the sensor detects lack of flow and kills the engine, aren't you going to want to check the impeller anyway? It could be the reason for lack of flow. On the other hand, if it's the sensor that is defective, you'll end up needing to disconnect it from the fuel pump to use your motor.
I actually purchased the same sensor for my main engine and haven't gotten around to installing it yet. I had to cut the old one out (diff part), as it was defective.
Jeanneau 54DS
Minnewaska is offline
post #3 of 7 Old 10-17-2015
al brazzi
I second that, I would want an alarm and manual shut down especially on the main power plant. I wouldn't interlock the fuel maybe the engine cut-off, on Diesels of course there are different types of cut offs so its tricky to do that. but unless its something you would sleep through I would keep it manual. But I haven't used one YET!! I like the idea.
I just checked the site they have a nice cheap panel ($46) you can get one for two locations for $75
albrazzi is offline
post #4 of 7 Old 10-17-2015
captflood's Avatar
GREETINGS EARTHLINGS , sound a good idea. Some years ago a carrier bag got into the water intake on one of the sail training vessels I was on (75') and took out the engine as we where coming into port scary indeed playing touch and go in a confined space with paying people onboard not a good inpression. The came in past the grid strainer round the frongs of the inpeller melted and stopped the water 5000 latter ($8000) and a new head engine fixed.AS ALWAYS GO SAFE
captflood is offline
post #5 of 7 Old 10-17-2015
al brazzi
I had a similar incident although didn't lose anything but the impeller, shut down in enough time but surely there was some luck there too.
I like the alarm more and more as I think about it.
albrazzi is offline
post #6 of 7 Old 10-17-2015 Thread Starter
Master Mariner
capta's Avatar
The Onan is a generator, not the ME. As stated, the ME will have an alarm.
Our Videos;
capta is offline
post #7 of 7 Old 10-17-2015
I understand. I only referenced my ME, since that's what I bought the alarm for. My advice was the same for your genset.
Jeanneau 54DS
Wiring Help Please cjmcfall Gear & Maintenance 10 12-09-2013 11:22 PM
Bilge Pump (aqualarm) cheoylee26 Gear & Maintenance 6 02-20-2012 09:35 PM
AM/FM/CD Wiring Harness ccriders Gear & Maintenance 8 03-22-2010 09:22 PM
6v wiring Acadia Gear & Maintenance 7 11-16-2008 12:43 PM
Wiring drynoc Gear & Maintenance 10 05-08-2005 08:24 PM
