Please ID this fitting - SailNet Community
post #1 of 10 Old 10-18-2015 Thread Starter
s/v Passport, Bianca 111
This is a picture of the deck fill on a Danish made Bianca. I should have also taken a picture of the inside but its basically a half thread so you just turn these 1/2 turn to close.
I need gaskets and now I need a new plug as one just cracked. I have never seen these before and need help identifying who the manufacturer is and/or who makes parts. Used ones would be fine too.
Icarus05 is offline
post #2 of 10 Old 10-18-2015
Re: Please ID this fitting
What year is the boat? That manufacturer may well be out of business.. is that a polar bear or? on the logo?
I think I'd take the original to a machine shop and have them spec it out (ie identify the thread at least) so that they might recreate it or give you enough info to find a compatible replacement.
In the end, though, it may make more sense to replace the whole thing.. they seem to be readily available for under $100.
http://www.go2marine.com/category/11...aps-fills.html
Faster is offline
post #3 of 10 Old 10-18-2015
Master Mariner
capta's Avatar
I assume you are referring to the o-ring that goes on this cap? O-rings are pretty standardized and you shouldn't have a lot of trouble coming up with one to fit it at an industrial tool and parts supplier. Even your local auto parts store might have what you need.
If, on the other hand it is a cork or fiber gasket you need, both the above mentioned stores should sell gasket material from which you can make a replacement very easily.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #4 of 10 Old 10-18-2015
travlin-easy's Avatar
Huge selection of "O" rings at Home Depot.
Good luck,
Gary
travlin-easy is offline
post #5 of 10 Old 10-18-2015
.. but he also said the cap is cracked... agree the oring is the easy part.
Faster is offline
post #6 of 10 Old 10-18-2015
overbored's Avatar
had the same one on my Soverel 33 fuel tank and tried to identify it. never did. takes a special square o ring and could not find one so I changed the the entire fitting.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #7 of 10 Old 10-18-2015 Thread Starter
Thanks for all the replies. At first it was just the gasket that I needed. It was very difficult to replicate but did ok with some sheet rubber from McMaster. The original was a very soft "rubber" or maybe neoprene. It was about 1/8" thick and a 1/4" wide.
Now, as Faster said, the actual plug (center bit) cracked.
There are not threads per se. Just a plastic tang on each side that slope around on an angle (single thread of sorts) and that is received by the metal deck fitting which as a metal lip on the inner edge with two slots.
The closest I found found was on RigRites site Amiot Deck Fills. These Amiot look very similar but have threads where mine do not.
Yes I think its a walking Polar Bear.
I would very much like to keep the original fittings.
Icarus05 is offline
post #8 of 10 Old 10-18-2015
RichH's Avatar
The cracked plug can probably be welded/repaired by a good metal working 'welder-artist'.
The 8-point (only 6 points are triangular, 2 are square) winch handle recess is probably poor design in that its possible to have only 2 of the triangular points in contact with the 'business end' of a winch handle. With only two points engaged it would be very easy to apply too much torque to 'cap' .... crack!
Id be sure that any winch handle is ONLY in full 4-point contact with this deck fill plug, not just 2 which is quite possible with this design.
O-rings are a dime a dozen from the internet. Measure the OD and ID of the O-ring recess in the 'housing' measure the apparent diameter of cross section of the O-ring .... all to the closest 0.003-0.005 inches or metric equivalent
Id recommend VITON o-rings, as with so-called bio-fuels, especially those made with 'reclaimed' cooking oil (sometimes added to 'regular' fuels by unscrupulous marketeers), as Neoprene/BunaN will soften, swell and grossly distort in contact with such 'bio-fuels'. You want the softness of the O-ring in the range of 50-70 'durometer'.
Try Amazon; if not, then McMaster-Carr, or a Parker O-ring distributor.
http://www.mcmaster.com/#o-rings/=zfbrpo --> multipurpose --> Viton
RichH is offline
post #9 of 10 Old 10-18-2015
Yes, that recess had me scratching my head. Not that I can claim to have seen a huge number of deck fills, but I've never seen anything like that, nor can I think why it was made that way unless to allow several types of "tools" to turn it.
ggray is offline
post #10 of 10 Old 10-18-2015
Looks to me like the plug is plastic or nylon?
Faster is offline
Fitting Punishment? RobGallagher General Discussion (sailing related) 25 09-18-2013 07:31 PM
mystery fitting flo617 Gear & Maintenance 21 03-04-2013 09:05 PM
What is this fitting? davidpm Gear & Maintenance 12 05-06-2010 05:16 PM
Name that fitting... cghubbell Gear & Maintenance 12 08-28-2009 08:13 AM
Fitting a bowsprit to a First 40.7 jlaake Gear & Maintenance 4 03-05-2006 10:11 AM
