Blogs
User Name
Old 08-30-2006
ktucker8 ktucker8 is offline
ktucker8 is on a distinguished road
Shroud Tension Update
Well Thanks to you all for taking the time to warn me on these chain plates and to get the rigging inspected plus advise! The welder I had sent the chain plate to has called me and said there is numerous stress cracks in the chain plate so he is making me a new one. You folks were right! i will definitly be pulling the other 5 plates to have them inspected1 then I will get the boat over to Svendsen's in Alameda to have the rest of the rigging inspected! I appreciate your time in guiding this Newbie! Ken
Old 08-30-2006
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
You're welcome Ken... we'd rather have you take the time and get the rigging checked out..than have you check out...
If you're new to the Sailnet Forums... please read this POST.
Old 08-30-2006
knothead knothead is offline
knothead will become famous soon enoughknothead will become famous soon enough
Good choice Ken. The only thing i'll add is that often it's a good idea just to bite the bullet and have the stick pulled. That way you can pull all the chain plate at the same time and have them duplicated. Oh yeah, since you are going to pull them all, just have new ones made. Don't put the old ones back even if you don't see anything wrong. It's money well spent. It may cost you a little less if you don't take them in one at a time also.
You can use the opportunity to check everything on the mast while it's down. It is easier to do a more thorough inspection with the mast on horses. You can check lights, sheaves, lube the track etc. You can remove the stays and shrouds and lay them out to get good measurments. You will know your boat better and get some peace of mind.
Sponsored Ad
Old 08-30-2006
It might also be worth taking the screws out of the mast fittings, and coating them with anhydrous lanolin or Lanocote, and putting them back. This will help to help prevent galvanic corrosion from occurring.
If you find any areas with a lot of white powdery material..that is probably someplace that you've got a galvanic corrosion problem, and it should be cleaned and investigated further.
Old 09-01-2006
I have 4 new chainplates made of 304 stainless to install this weekend! I am going to pull the fore and aft ones next. Ken
Old 09-03-2006
I would recommend that you get 316 stainless chainplates rather than 304 stainless...because 304 stainless has known issues with chloride stress cracking in saltwater environments IIRC. 316, although not quite as strong, will generally last longer, due to the higher corrosion resistance IIRC.
Display Modes
vB code is On
Shroud tension ktucker8 Gear & Maintenance 31 08-29-2006 10:25 PM
Trip Update NewsReader Mass Bay Sailors 0 08-28-2006 01:15 PM
Shroud Tension john66 Gear & Maintenance 3 09-17-2002 05:56 PM
Standing rigging tension on a 21''7" Kingfisher Claus Gear & Maintenance 0 08-12-2002 05:15 PM
update: moisture trapped between two gelcoat layers tappers Gear & Maintenance 1 01-12-2002 07:23 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
