Adding a second bilge pump - SailNet Community
 3Likes
post #1 of 17 Old 11-09-2015 Thread Starter
I am thinking of adding a second bilge pump to my boat. The current bilge pump is way to small and very high up and as a result the bilge has a constant amount of water in it.
My current plan, I only started planning this last night would be to add a diaphragm pump outside of the bilge with a float switch way down low in the bilge. Then add a larger centrifugal pump in the place the current pump is as a backup to the diaphragm pump.
The current pump is plumbed through the manual gusher to its through hull.
My question is would a second bilge pump need its own plumbing and own through hull?
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #2 of 17 Old 11-09-2015
HANUMAN
RobGallagher's Avatar
Re: Adding a second bilge pump
I would say that it should have it's own plumbing, wiring and through hull.
Of course it an be done with short cuts but that might defeat the purpose and advantages of redundant systems.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #3 of 17 Old 11-09-2015 Thread Starter
Kind of what I was thinking also. Way too many shortcuts done on this boat in the past and I am trying to reverse that trend. I wish the confidence in my mechanical skills included drilling holes in the exterior of the boat.
Can someone suggest which type of diaphragm pump I should be looking at? Also would it be a sound design to either the diaphragm pump or centrifugal pump inline with the gusher pump?
Jordan
Oceanside CA
jephotog is offline
post #4 of 17 Old 11-09-2015
krisscross's Avatar
How about installing one good pump in the place of the substandard pump you have now? Adding through hulls to your boat is just not a good thing.
Skipper Jer and bobperry like this.
Plato
krisscross is offline
post #5 of 17 Old 11-09-2015
Master Mariner
capta's Avatar
I agree with adding all new plumbing and wiring. Adding a thruhull way above the waterline should be no problem. A diaphragm pump, as you described is definitely the way to go if you don't want back flush from a submersible, which will always be in the bilge.
Question; when using the gusher, what stops water going back into the bilge through the submersible?
facebook.com/svskippingstone
Our Videos;
capta is offline
post #6 of 17 Old 11-09-2015 Thread Starter
In the year I have been involved with this boat I have twice had one portion of the bilge pump system fail wire connections and float switch. I have fixed both portions of that but if either part of the system were to fail now I am sunk.
Also there is currently an excessive leak in the stuffing box. Until I can pull the boat and address the issues around the engine shaft addressed it is cheap insurance and gives me the incentive to make it right. I think a two pump system is the recommended way to go anyways.
Not sure but from my hours of knowledge on this subject, a few hours studying this morning... The gusher should have a check valve on either side of the input and output side to work. Which I am now thinking it probably a no-no upstream from the centrifugal pump.
So far i have only been handling the wiring aspect of the wet end of the bilge pump system between pumps and switches. I am now trying to address the entire system.
Jordan
Oceanside CA
jephotog is offline
post #7 of 17 Old 11-09-2015
I like your plan. Two complete redundant systems is the way to go. Use smooth hose and be sure to check the ability of your chosen pumps to lift water to the height of your overboard discharge. They degrade quickly with every foot of rise. A small convenience pump (I like the diaphragm as it won't backflow), backed up by a big dog is the way to go. No check valves, be sure you can activate both manually and automatically. IMO.
Jeanneau 54DS
Minnewaska is offline
post #8 of 17 Old 11-13-2015
davisr's Avatar
Here are two articles on how I addressed this issue on my own boat, Oystercatcher.
Ericson 25, Oystercatcher: Electrical, Bilge Pump Switches, Part I: Analysis and Installation
Ericson 25, Oystercatcher: Electrical, Bilge Pump Switches, Part 2: Wiring
Roscoe
Roscoe
Ericson 25, #226
Oystercatcher
davisr is offline
post #9 of 17 Old 11-13-2015
bob77903's Avatar
I did exactly what you are wanting to do. Added a larger centrifugal pump, and put in a diaphragm pump to dry the bilge. Each is a separate system. The diaphragm pump will pump the bilge dry, with no hose return when shut off. This is the pump I have, and I have no affiliation with Defender.
Jabsco 36960 Series Diaphragm Bilge Pump
bob77903 is offline
post #10 of 17 Old 11-14-2015 Thread Starter
In looking at products I contacted Whale Pumps.
They recommended this product.
Whale Bilge IC Automatic Remote Mounted Bilge Kit
Save you from having to buy a strainer and float switch and it has an integrated circuit that pumps for X number of seconds after water stops lifting float switch to run the bilge dry. It looks like a nice integrated unit.
Jordan
Oceanside CA
jephotog is offline
Bilge pump cutoff delay? Narrow bilge Pamlicotraveler Gear & Maintenance 41 11-02-2014 12:44 PM
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 08:59 AM
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 07:26 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Brand new bilge pump that doesn't pump.... ugh Lancer28 Gear & Maintenance 6 02-08-2008 08:26 PM
