Which Flat-Panel TV? - SailNet Community
Blogs
Old 09-04-2006
johnr
jr438234606 is on a distinguished road
Dockside I like to catch local weather reports (and yes, an occasional movie ) and therefore keep my boat equipped with a TV. As my old tube is on the blink, I'm looking to replace it with a low-power-consumption LCD, 12-volt, flat-panel device in the 15" - 17" range. I see 120VAC devices all day long, but I would rather not run it through an inverter.
Can anyone make a suggestion for an inexpensive set (other than the 800 - 1500 dollar variety sold by West Marine)
Old 09-04-2006
try one of these
Old 09-04-2006
catalyst27 is on a distinguished road
you also may want to inspect the tv's a little closer as i have found some to have a conversion cable from 120 to 12v and after consulting with the reps found out that alot of the newer tvs are being converted to 12 from 120 due to the components being more durable so in reality i can hard wire the tv into the batts and not have to worry with the 120 side of it
Old 09-05-2006
I would recommend a visit to Circuit City in person, to look at the TVs in person. This is for two reasons: 1) Check out the picture quality; 2) Check to see which units are DC-powered. A good number of them are, using a wall-wart type transformer to convert the AC to DC.
Old 09-05-2006
hsilvermanmdjd is on a distinguished road
Send a message via AIM to hsilvermanmdjd
SatTV
I don't know your financial situation but if you can swing it, the new KVH TracVision Sat TV Receiver is a great add to your TV set-up. We are die hard Red Sox fans (suffering of late) and we didn't miss a game all summer.
Old 09-05-2006
MikeinLA's Avatar
MikeinLA is on a distinguished road
I just finished installing a 26" Sharp Aquos widescreen LCD TV in my Cat 36. It was about $ 975 . I highly recommend the Sharp Aquos brand having moved up from a 20". I must say the installation job went absolutely splendidly (hand patting back).
Mike
Old 09-05-2006
camaraderie's Avatar
moderate?
Since all the TV's sold in the stores run off AC...you need to look for ones which use a converter between the wall plug and TV then READ THE SPECS on the converter box and look for one that features 12V OUTPUT...then you can safely clip the wire and run it off your batteries.
Second...you will find big price differentials between sets depending on ther HDTV capabilities. Do you NEED HDTV built in or not? If you plan to hold on to ths boat for a while, I would suggest getting one with a built in HDTV tuner UNLESS you will be hooking up to a satellite dish which will need it's own HDTV tuner box.
Finally...I would avoid the "no name brands" which include many old and famous brands that have been "repurposed" by far east fatories and go with brands that actually have manufacturing.capabilities...Sony,Sharp,Philips(ma gnavox),Samsung,Toshiba are all good choices IN THIS SIZE RANGE.
Old 09-05-2006
abj87 is on a distinguished road
If you cut out the ac adapter the tv is susceptible to voltage fluctuation and spikes which may fry the tv. I'd use a small cheep inverter.
Old 09-06-2006
Not if you use a good stabilized DC-to-DC power supply, like that used on DC-powered computers.
Old 09-06-2006
foxglove's Avatar
foxglove is on a distinguished road
Maybe a laptop?
Last year, we bought a laptop computer for under $600 (after rebate). We watch tv on it via cable and an ATI adapter/software which will also record tv shows while you are gone (at home or on board). It will even record the show as you watch so if you delay it for 15 minutes, you can skip the commercials.
We watch movies on it which we rent from Netflix, so there is no late fee for having it for a couple weeks.
We have Maptech software on it including the chart which came with the paper charts we bought for $100.
And our marina has free wireless internet, as many are installing.
It seems that the smaller the screen on the computer, the cheaper is the computer. I think smaller laptops are valued because they are lighter but you want to watch a larger screen so that is an advantage.
I think a laptop is the best choice.
Don't drop it overboard.
Inverter/Alternator/Solar Panel Control ABullard Gear & Maintenance 1 04-30-2002 08:41 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
