12v Appliances - Good/Bad/Ugly? - SailNet Community
post #1 of 14 Old 09-05-2006 Thread Starter
Shack's Avatar
Question 12v Appliances - Good/Bad/Ugly?
What 12v appliances are a waste of what would otherwise be good amperage?
I am planning an electrical system for a future boat. I'm finding many 12v versions of common household items such as washers/dryers, micowaves, fridge/freezers, etc. However, I have no experience with their actual performance. Inverters are always an option, but 12v appliances seem so simple. From which appliances should I steer clear?
-Shack
Shack is offline
post #2 of 14 Old 09-05-2006
pigslo's Avatar
I had a 12 volt coffee maker that I threw in the dumpster after it took too long to brew a pot.
pigslo is offline
post #3 of 14 Old 09-05-2006
Best Looking MALE Mod
Cruisingdad's Avatar
My opinion:
You are probably better off dropping in a good inverter, like a Xantrex Prosine with a true sine wave. Sailnet has them for $7XX dollars, I think. Seems like a lot of money now, but a good sine wave is easier on most components, and it is easier to go throw the switch and just plug in whatever you want. Maybe it is even cheaper that way in the long run????? Others might be able to answer that better.
Most things on a boat run on 12V though. My only caution is that it is really easy to suck down a battery with a inverter if you are not careful. Watch your juice!
Take care.
CD
Cruisingdad is offline
post #4 of 14 Old 09-05-2006
A lot of the 12V appliances are poorly engineered and designed. In many cases, even though it isn't theoretically as efficient, it may make more sense and be less problematic to get a larger battery bank and use an inverter. It sounds like you're planning on a fairly large boat, so the inverter and large battery banks shouldn't be much of an issue. Anyone talking about a washer/dryer setup isn't talking a small boat.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
post #5 of 14 Old 09-05-2006 Thread Starter
Shack's Avatar
Big Boat?? Yes, sir. I'm on a long term plan to build a dream boat. I'm starting small but plan to finish big in the next 4-5 years. I was hoping for some design simplicity by reducing the AC footprint.
C-Dad's recommendation on the $700 inverter may be simpler as well as a more economical solution in the long run. Most of the 12v products I have found cost about twice as much as their standard AC counterparts. I'm not sure if they're ruggedized for marine environs, either.
Thanks for the input.
Shack is offline
post #6 of 14 Old 09-05-2006
moderate?
camaraderie's Avatar
Shack...the inverter is the ONLY way to go. I disagree with the pro-sine recommendation for extended cruising as the idle amp usage is prohibitive. Suggest modified sine-wave like Heart and if you need pure sine wave for sensitive electronics then get a small pure sine. Most items that "prefer" pure sine waves are charging applications and require little amperage or can be charged from 12V adapters.
Our Heart 2500 runs everything from microwave to flat screen and we have yet to need a new adapter for anything. Made by Xantrex just like the pro-sine.
camaraderie is offline
post #7 of 14 Old 09-05-2006 Thread Starter
Shack's Avatar
Now I'm really interested. I'm aware of square waves produced some inverters and have watched sailors argue about good, better, best . . .
The true sine wave seems better for the hardware , but the square and stepped wave inverters sound like they are more efficient (% amps used). If I am correct then I guess that is the great paradox.
I have read where equipment sensitive to and prefering the true sine wave are likely to be tv's, nukers, NiCd chargers, and some types of variable speed devices. (Doc Casey's Sailboat Electrics Simplified, 1999). I some experience with inverters on aircraft for which the avionics have a need for styles of waves (to include phased sine waves). Now I find myself asking if my toaster has any special needs when compared to my laptop or table lamp. Humbling . . .
It appears that most of the gear one needs can be lumped into being supported by one style of inverter (i.e. Heart 2500)? The rest are exceptions, for which I can devise an exception to meet their needs (i.e. Prosine).
Thanks for showing me the fine print. This helped.
Shack is offline
post #8 of 14 Old 09-06-2006
moderate?
Shack...the Heart is a "modified" sine wave device so it is probably tolerated a lot better by some devices which don't like the old square wave inverters. From 5 years of cruising with 2 different Hearts on 2 different boats, I can say that CURRENT vintage microwaves and Flat screen TV's do just fine with them and they also do a great job of charging my 1100AMP house battery bank! We also run the toaster oven, "Mr. Coffee", computers and hairdryers from the Heart with no problems.
As you design your system for cruising you will need to have a lot of focus on your battery system and charging system and there are lots of threads here and on the SSCA.org board that can provide good technical advice. I would only add that whatever you decide on for a system that will meet your needs....get yourself a LINK 2000 to monitor it and understand what is going on daily with your charge/use/re-charge cycle. Really is invaluable.
post #9 of 14 Old 09-06-2006
Surfesq's Avatar
Camaraderie: I am curious as to why you did not go with a generator for long term cruising? I am not suggesting one is better than the other.
I bought a DC powered Flat Screen for my boat. Also, my laptop has a DC plug.
Surfesq is offline
post #10 of 14 Old 09-07-2006
moderate?
Surf...we have an 8kw generator but we still need AC for when we don't want to be running it. Kinda stupid to run a big gen for a little TV...makes it hard to hear too! We use the Gen to charge the battery bank through the Heart and to run the Airconditioning/Heat when at anchor if needed. Using the Gen to run an A/C hi capacity charger is much more efficient than using the engine/alternator though that is upgraded as well as I like to have backup. We use the Link to monitor the charging V & A and amp hour use.Hope that explains things a bit.
12v Fans for ports halyardz Gear & Maintenance 2 12-30-2001 05:14 PM
