  #21 (permalink)
Old 09-11-2006
Rockter will become famous soon enough
The two-cycle engine is much simpler, and lighter. Indeed, you will smile broadly when you open it up to see what's inside. In it's simplest form, the prime mover will have 3 working parts.... plus the gearbox, if it has one.
The two cycle will use more fuel than the four cycle.. about 1/2 as much again, particularly when worked hard. A two cycle outboard, like the motorcycles, realy drink heavily when thrashed.
If you are not going far, I would stick with the two cycle, certainly for use with your tender.
If you are going far, and not in a hurry, the four cycle is where it's at.
  #22 (permalink)
Old 09-11-2006
Canibul's Avatar
Canibul is on a distinguished road
You are right about fuel economy with a two stroke. It treats gasoline like someone drinking water from a free flowing garden hose.
  #23 (permalink)
Old 09-11-2006
From a motorcycle... the now discontinued GT 500A Suzuki, a two cycle twin.
My own one will manage, when nursed, 53 miles per galllon (Imperial). I have done that one a few times.
From an old road test, back in 1976, when thrashed.... wait for it..... 19 miles per gallon, Imperial. I have never tried that one.
Thats 2.78 as a ratio, or 35% of the distance per gallon when thrashed.
Two cycles really are not economical when thrashed.
1981 Honda 9.9, 4 stroke o/b, Idle problem randj65 Gear & Maintenance 4 06-19-2002 10:59 AM
