Old 09-24-2001
cmj cmj is offline
cmj is on a distinguished road
Dry Compass!
Hi all
The yacht I crew on has a mounted compass which has lost all its internal fluid. There''s no obvious hole. What is the fluid, and how can it be replaced?
Thanks
Old 09-25-2001
CwC0712 is on a distinguished road
Dry Compass!
The fluid inside is mineral water. You can buy it at and marine store. Inside the compass underneath is a rubber seal that allows the fluid to expand when it''s warm. If it''s an old compass the rubber seal may be cracked. Or it can be loose. If it''s cracked you''ll need to get another.
Old 09-30-2001
alanporter is on a distinguished road
Dry Compass!
The usual fluid inside a compass is a type of thin oil which has a low freezing point. This is not always readily available unless you have contact with a professional compass repair facility. I have used methyl alcohol (methanol, methyl hydrate) in my compasses for many years. It has a low freezing point and provides good dampening qualities for the card.
Overhead compass? mmccoy Gear & Maintenance 10 12-27-2009 11:47 AM
Compass adjuster greatwhiteway Gear & Maintenance 1 06-28-2003 04:07 AM
N hemispere binoc w compass not working in S? bullseye Gear & Maintenance 2 08-09-2002 07:46 PM
"Swinging the Compass" duke General Discussion (sailing related) 1 11-23-2001 08:24 PM
"Swinging the Compass" duke Seamanship 0 11-19-2001 04:46 AM
