If I correctly understand what you are saying, it is that you calculated the required amount of solar amperage to "
extend" the battery life to a point that matches my time away from the boat.
However, I would prefer to return to the boat (after an absence) with a full batt bank, and not have to lightup the engine or gen to begin a charge cycle.
To do this it would seem that what I need to do is simply maintain a charge capacity in excess of the draw. An excess charge capacity should charge the bank as well as maintain a floating charge after its topped off.
Wouldn't the critical item here then be a charger controller that can collectively monitor the inputs from charging devices (i.e. solar, and wind) and also change the charging voltage to correspond to the state of the batt bank?
Change Tack - Now, when away from the boat - the math would be fairly simple as the draw would remain fairly consistent from day to day. The tricky part would be the varied draw when using equipment while aboard. I would still need to establish means for replenishing the bank with this higher rate of use. Naturally, amp draw while board would be higher than while away. This now gets into the issue of charging and using simultaneously.
I think I need to jump into the Parrallel Battery thread, too.
