Old 09-08-2006
wumhenry is on a distinguished road
manual oil pump
The manual for the Universal diesel in my Bristol 29.9 says to use a manual pump inserted in the dipstick hole, not the drainplug, when changing the oil. The guy who sold the boat to me told me his manual pump didn't work too well for that purpose. Anyone: is there a brand and model of manual pump that you swear by for this purpose?
Old 09-08-2006
We have a fitting in the drain plug hole with a length of hose permanently attached (and capped off) This hose is stowed in the engine compartment so that the end of it is well above the oil sump.
To change the oil we connect on one of those vacuum pump oil reservoirs: http://www.westmarine.com/webapp/wcs...allpartial/0/0)
to the hose, pump up the vacuum and the oil runs cleanly into the pump tank. We are pulling off the drain plug, the lowest point on the pan and it's a larger diameter hose than what can fit into the dipstick tube. Works well and there's no handling of oil other than dumping the self contained tank into the recycle tank.
Then for the oil filter I place an oversized plastic bag around it as I spin it off(ours is at an angle), any oil that runs out is captured before it hits the block or the bilge..
Old 09-08-2006
capttb is on a distinguished road
Most seem to work well as long as the oil is warm enough, just idling at the dock usually isn't enough, drive around the harbor a little.
Old 07-02-2007
theArchitect is on a distinguished road
Wumhenry, what did you end up going with? I also have a Bristol 29.9. Thanks!
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
Oil Change Pump?? ikent Gear & Maintenance 3 07-22-2003 06:26 AM
Bilge Pump Discharge - New Thru Hull ??? Terry Clarke General Discussion (sailing related) 4 05-10-2003 05:07 PM
Bilge pump GeorgeTay Gear & Maintenance 4 04-03-2003 03:03 PM
oil pump thomasstone Gear & Maintenance 1 01-14-2002 06:17 AM
