Old 09-09-2006
bmelchionda is on a distinguished road
Diesel Engine Problem
On my first day of solo sailing (would it happen any other way?), as I'm backing out of the slip, once I place the diesel engine in reverse, she dies on me. I tried a couple of times, and no avail. I then attempted in forward, again she dies. I never had a problem prior to this instance.
I waiting about 15 minutes (engine off), tried again and she ran fine.
Any ideas of what caused this?
Thanks!
Old 09-09-2006
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
You can always go back to the age old rules about diesels. There are 3 things that will make a diesel die. Fuel, Fuel and Fuel.
I would look at the fuel.
Old 09-10-2006
sundown2 is on a distinguished road
is there anything fouling the prop or the prop shaft? IE: can you turn the shaft by hand (with the engine shut off and out of gear)
Old 09-10-2006
bsfree's Avatar
bsfree is on a distinguished road
Assuming your fuel system is good, filter clean etc, the one other thing that stops a diesel running is air in the fuel line. You may need to bleed air from the system.
Old 09-11-2006
pigslo's Avatar
pigslo is on a distinguished road
A line wrapped around the prop could do this although usually in only one direction.
Old 09-12-2006
ebs001's Avatar
ebs001 is on a distinguished road
As this only happened when he put it in gear it doesn't sound like a motor problem. The chance that fuel problems would only occur when put into gear are very remote. Something around the prop or drive shaft sounds far more likely. As pigslo said a line would usually do this in one direction which may account for why it didn't occur when he tried it the third time - he unwrapped it when he put it in forward. The other problem that might cause this is a transmission problem.
Old 09-12-2006
Lecy is on a distinguished road
Does the fuel have a history of being treated with a biocide for black algae? If not, the algae can clog the pick up line in the fuel tank. The vacuum on the diesel engine is very powerful and if it's not getting fuel due to a clog it can suck in air through a loose fitting. When an air pocket hits the injectors the engine dies. If you bleed the diesel when it dies, foamy fuel means it has air in the fuel. If it hasn't been treated with a biocide, it's a good time to start. FPPF makes a good product and I think Starbrite makes one, too.
Also condensation or water in the fuel due to a leaking deck fill can kill the engine. Check the o'ring on the deck fill to make sure it's there and not cracked and damaged from spilled diesel. What does the exhaust look like? Theoretically diesel exhaust is clear. A white exhaust can indicate moisture in the fuel.
Just a couple thoughts from personal experience. I believe that to be a good sailor in the 21st century you have to be a good mechanic. Good luck!
Isuzu C240 Diesel Engine Troubleshooting soflajo Gear & Maintenance 6 07-28-2009 04:16 PM
Diesel Problem: Glow Plugs in a Nanni (Mercedes) RichH General Discussion (sailing related) 1 04-21-2003 09:06 AM
Engine Oil Problem soylentgreen Gear & Maintenance 4 08-16-2002 10:17 AM
Engine Exhaust/Yanmar Problem plong Gear & Maintenance 5 08-30-2001 10:46 PM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 06:25 PM
