Treadmaster Removal - SailNet Community
post #1 of 2 Old 8 Hours Ago Thread Starter
Treadmaster Removal
Treadmaster Removal
After trying all sorts of methods of removing Treadmaster I have settled on using a belt sander
with 36 grit paper. A couple of days I should have it removed off my Vancouver 27. I was looking forward to tackling this December. The process will take off some gelcoat. I will be, I think replacing with Treadmaster as rolls of it came with the boat. I will be using an epoxy that should have 60+ degrees to set. I will not see this temp until spring. With some gelcoat remove is there a chance of moisture getting into the deck over the winter? Itís one of those dirty jobs you want to get done.
The boat does have a cover but Vancouver can be pretty moist in the winter.
gp nesbit is offline
post #2 of 2 Old 7 Hours Ago
Re: Treadmaster Removal
I wouldn't get too worried, if there won't be standing or running water on it over the winter. I would fair the surface with epoxy or gelcoat, before gluing or applying the new non-skid.
Jeanneau 54DS
Minnewaska is offline
Treadmaster removal k1vsk Gear & Maintenance 2 11-25-2006 03:43 AM
Treadmaster tdw Gear & Maintenance 5 10-09-2006 12:41 AM
Treadmaster bduning Gear & Maintenance 2 06-01-2006 04:18 PM
treadmaster mary jewell Gear & Maintenance 0 05-04-2004 09:58 PM
Treadmaster removal joseph53p Gear & Maintenance 1 11-16-2001 01:49 PM
