Old 09-13-2006
TXS-ALAMO is on a distinguished road
Cool Restart Diesel After Layup
What precautions should I take before starting my Perkins 4-108 after it has been sitting idle for a year beyond checking oil and water? It was not "winterized" as the only icey roads we see down here is when someone tosses his bourbon on the rocks out his car window.
Old 09-13-2006
camaraderie's Avatar
moderate?
You might consider changing out the impeller...dry for a year could end up in pieces in your heat exchanger.
Also..change our your Racor filter as all sorts of things could be growing in your diesel fuel tanks by now. (A fuel poilish would be a good idea.)
Work the manual fuel lift pump lever on the engine to insure the diaphragm has not cracked and you get good fuel pressure at start up.
Then crank her up! (Change oil at first opportunity as there are probably acids and contaminants built up.)
Good luck!
Old 09-13-2006
Smile restart
Thanks, I completely forgot about the impeller and would have done so until the overheat alarm went off right after the engine was ruined!
Old 09-13-2006
Rockter will become famous soon enough
I think it will probably start ok. Don't try to run the starter for too long. Try it in bursts, perhaps 30 seconds apart. If the starter has to run for a long time, SHUT THE COOLANT THROUGH-HULL!!!!!... or the exhaust will fill with too much water and often it invades the combustion chambers.
Check that you are circulating water once it starts.
Damn good engine too, and reasonable spare part prices.
Diesel Maintenance and Repair Classes ABullard Gear & Maintenance 11 05-20-2011 12:58 AM
Diesel vs 4 stroke outboard??? bugged Gear & Maintenance 21 11-28-2010 06:15 PM
fuel consumption gas vs diesel jklewissf Gear & Maintenance 19 09-12-2009 09:01 PM
gas vs diesel reid5009 Living Aboard 1 02-07-2003 12:43 PM
diesel tachometer diesel MHRitter Gear & Maintenance 1 09-17-2002 11:52 AM
