09-14-2006
If there is any sediment, algae, debris on the bottom of the fuel tank, going outside, and the rougher conditions there can indeed stir up the fuel and raise the debris, algae and such to the point where it gets picked up by the fuel pump intake. That can cause the fuel filters to clog or the fuel pump to clog. What you probably should do, more than just filtering the fuel, is to clean out the fuel tank.
