09-14-2006
If the PRC1500 has NMEA output, then you should be able to connect it to an NMEA input on the Miniplex and then a computer connected to the Miniplex should see the NMEA data from the AIS unit. You should be able to connect one computer to the serial port (RS-232) and the other via the BT interface.
Whether the ship plotter software understands the NMEA data AIS information is really dependent on the program and how it was written, etc. You will probably need to configure the software to read the data from the proper port on each machine.
