Old 09-14-2006
dsbentley's Avatar
dsbentley is on a distinguished road
Send a message via AIM to dsbentley Send a message via MSN to dsbentley Send a message via Yahoo to dsbentley
Jib or Wisker pole
I am looking to get a pole to hold the jib out while sailing downwind. I was told I need 110% of my J lenght which for my boat is over 34'. This seems long to me and I am told I need to have a carbon fiber pole for weight reasons.
Old 09-14-2006
paulk's Avatar
paulk is on a distinguished road
34' IS a long whisker pole, but you've got a big boat. If you're trying to wing out the flying jib on the end of your bowsprit, that may be what you need. Winging out the inner jib you may be able to get away with something shorter, and just furl up the outer one. For the carbon fiber reasoning, try picking up something fairly long that might be strong enough for some of the forces you're dealing with - say a J/24 mast, for example. If you had to handle something like that - or longer! - on the foredeck, you'd be wishing pretty quick that it was carbon fiber and weighed half as much as an aluminum one. It might be easier (and cheaper!) to fly an asymetrical chute from the bowsprit, and play the angles on downwind legs.
Old 09-15-2006
Gene T's Avatar
Gene T is on a distinguished road
I'm with you paulk. I can't imagine handling a pole like that, let alone the risk of dipping the end and what damage that could do. Maybe something like a code-0 on it's own furler. It would certainly be easier to handle.
Old 09-15-2006
Agreed. With a boat that size, manhandling a pole that size and weight could be considered almost dangerous. Carbon would be better but rather expensive and still be somewhat unwieldly. Probably better off to play the angles as Paul suggested or look for an A-sail of some sort.
Old 09-15-2006
I guess a lot depends on how much crew you'll have to use the pole with. If you've got a huge (6'+) bowman, then a carbon fiber pole might be pretty reasonable, but if you're sailing short-handed, and with smaller, less-experienced crew, then I'd recommend going with a roller furled asymetric. I use a screacher on my boat for the very reason that it is far more manageable than using a pole and spinnaker.
Double Spinn Sheets davidk Racing 25 03-07-2007 01:22 PM
jibsheets while spinnaker''s up dpboatnut Racing 6 04-09-2004 07:21 AM
dousing a hanked jib terryny Seamanship 17 01-16-2003 05:19 AM
? pole for asym spinaker on O''Day 30 cb capnjim02 Racing 0 07-29-2002 01:28 PM
Whisker Pole vs Cruising Spinnaker r2straebel Gear & Maintenance 5 01-24-2002 08:25 AM
