watermakers - Page 2 - SailNet Community
post #11 of 37 Old 10-11-2006
bob46777's Avatar
Build your own watermaker
After pricing on the market watermakers I decided to build my own. I built a fully automatin 45 GPH watermaker for under $2000.00. I documented the build and have the plans for sale on ebay.
bob46777 is offline
post #12 of 37 Old 10-11-2006
美国华人, 帆船 教授及输送
Good for you Bob.
Water maker is not really a rocket science and parts are readily available. Most knowledge is open. Instead make a few bucks on eBay from a few poor sould, why don’t you share with other sailors. That is what this forum for. Who knows, one day the sailor that you help to build a water maker system may save your life on an open ocean?
OTOH, if have come up a proprietary membrane system to revolutionize the current approach, by all means market it your product. Make some serious bucks. My 2 cents.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #13 of 37 Old 10-14-2006
Plans for a 45gph watermaker are available in the January 2003 issue of Good Old Boat. I agree with rockDAWG, it's not rocket science. It also lists parts manufacturers with their telephone and e/snail addresses. Given this site's affiliation with the magazine perhaps the article can be accessed thru Sailnet?
TXS-ALAMO is offline
post #14 of 37 Old 10-18-2006
http://skwatermakers.net check them out
boog is offline
post #15 of 37 Old 03-03-2007
Could one buy a r/o watermaker intended for home use and boost the pressure up to 60 lbs with an auxiliary pump and use it on a boat?
kavakava is offline
post #16 of 37 Old 03-04-2007
A little less cheek
ianhlnd's Avatar
What the heck is the membrane? Is that the long cylindrical thing than sits on top of all the other stuff? I disconnected my wm 3 years ago because of all the mx. I use rainwater from the bimini for most of my supply all run through seagull IV filters. But would like to connect it back up, but don't know how (I forgot....it happens when you get old).
Is there some site I can go to that will give me the schematics for setting one up?
ianhlnd is offline
post #17 of 37 Old 03-04-2007
ian-
If you know who made your watermaker, you should probably contact the manufacturer...they can help you with reconnecting it, and also supply you with the necessary pickling chemicals, as well as a new membrane.
Kavakava-
I kind of doubt it. Most homes don't have R/O watermakers, but water filtration systems. I can't think of a reason a home would have an R/O watermaker, unless they were on a desert coastline, with no access to fresh water.
sailingdog is offline
post #18 of 37 Old 03-04-2007
engcon's Avatar
Thumbs down watermakers
I researched this some time ago with several Home R/O makers and this was what I found out.
Most of the Home R/O systems are intended for much lower Total Disolved Solids than that found in salt water. The membranes are also not intended for the pressure of a Salt Water R/O system.
engcon is offline
post #19 of 37 Old 01-25-2010
tdw
Super Fuzzy Moderator
tdw's Avatar
Anyone care to update the topic ?
Seems as if the technology is moving on.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #20 of 37 Old 01-26-2010
check out seapanel.com,it seems to be a way to go for only 250$
norsearayder is offline
Portable towed watermakers Mumec Gear & Maintenance 26 10-08-2007 11:51 PM
Home Depot selling Reverse Osmosis Watermaker''s chuck711 Gear & Maintenance 6 08-14-2003 04:08 AM
watermakers h2ojem Cruising & Liveaboard Forum 2 05-12-2002 05:48 PM
Spectre Watermakers plolson Gear & Maintenance 1 09-27-2001 05:52 PM
12 volt watermakers hunter100 Gear & Maintenance 0 12-02-2000 01:31 PM
