watermakers - Page 4 - SailNet Community
post #31 of 37 Old 03-05-2010
What about condesate watermakers? Not old steam water makers, but machines that chill air below the dew point to pull its moisture. Just a representative of the COTS products.
It does not have nearly the per minute output, but it can steadily generate water and can be encorporated into a AC or refidgeration system.
JamesG123 is offline
post #32 of 37 Old 03-18-2010
Anyone?
post #33 of 37 Old 03-18-2010
Best Looking MALE Mod
Cruisingdad's Avatar
Originally Posted by JamesG123 View Post
Anyone?
We have a dehumidifier on our boat. Sure can pull out a lot of water when it is warm. I would have to be pretty thirsty to drink it and it sure wouldn't be much - and our dehumid is a large one (took the one out of the house we sold and use it here... waste not want not).
You are better off with a watermaker.
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #34 of 37 Old 03-18-2010
If you're collecting condensate from a clean surface the water is perfectly distilled, which does make it taste a bit funny though as even RO water has quite a bit of minerals and other junk in it.
I'd quite like to build a small flash evaporator to use waste heat from the engine/generator or some type of solar still. With a decent vacuum you could make water at about 65ş and with a bit of refinement get quite a bit out of it.
SailD is offline
post #35 of 37 Old 03-18-2010
ex-Navy
bloodhunter's Avatar
We have a solar array (2 120-watt panels ) and we plan to add a wind generator. The array by itself has met all our electrical needs keeping our 700 AH battery bank fully charged. But admittedly we don't have any really heavy draws, just the refrigerator, lights, fans and electronics. With the wind generator I was assuming that we could handle a watermaker (Spectra 150 running an hour or two a day) as well. But, there seems to be a consensus on this thread that you need a genset tor un a watermaker so what am I missing?
Sufficient unto the day is the evil thereof
S/V Enchantress -- Morgan 45
bloodhunter is offline
post #36 of 37 Old 03-18-2010
No, you don't need a genset to run an RO watermaker, provided it is a relatively small unit. When setting up a watermaker, there will be a few things you will want to do that the watermaker manufacturer may or may not tell you.
First, you want the watermaker output to have a dedicated water tank. This is for a couple reasons. First, if the RO membrane fails, you aren't mixing salt water with the potable water in the other tanks. Second, it gives you a source of chlorine free water to backflush the RO membrane. Chlorine will destroy an RO membrane.
Second, you want to have some way to transfer water from this tank to the regular water tanks on your boat, but have a check valve so that water only goes from this tank—see above for why.
Third, you want to size the watermaker so that you don't necessarily have to run it every day...but more like every third or fourth day. This reduces the amount of water used to backflush the RO membrane percentage wise, but keeps the watermaker operating regularly enough that pickling the membrane isn't necessary.
Fourth, remember, you don't want to run an RO watermaker in the harbor. Bacteria and petroleum wastes are fairly common in the harbor and both will damage the RO membrane. An RO watermaker should only be run in clean seawater—harbors and populated areas rarely qualify for this.
sailingdog is offline
post #37 of 37 Old 03-18-2010
tomaz_423's Avatar
This is not for a boat, You can not have a device drawing 500W all day to produce 7 gal of water daily.
You will burn almost as much fuel in your generator as you will produce water..
Beneteau Oceanis 473
finished cruising after two years.
tomaz_423 is offline
Portable towed watermakers Mumec Gear & Maintenance 26 10-08-2007 10:51 PM
Home Depot selling Reverse Osmosis Watermaker''s chuck711 Gear & Maintenance 6 08-14-2003 03:08 AM
watermakers h2ojem Cruising & Liveaboard Forum 2 05-12-2002 04:48 PM
Spectre Watermakers plolson Gear & Maintenance 1 09-27-2001 04:52 PM
12 volt watermakers hunter100 Gear & Maintenance 0 12-02-2000 12:31 PM
