Old 09-19-2006
michaeldjordan is on a distinguished road
avon 310 Floor replacement
I have an avon 310 dingy that is missing the floor, I have the side extrusions. what are the dimensions of the floor panels? Should I just use marine plywood? what thicknesss? looks obout 1/2" but I'll bet it is a metric dimension.
Old 09-19-2006
can't re member
yotphix is on a distinguished road
Metric ply would just be 12mm, slightly undersized. If you have to you can shave a little at the edges with a power plane or on edge on a table saw with a tight throat.
Old 09-21-2006
still need dimensions
I still need the actual dimensions of the pieces. How does the floor fit around the inflatable keel? how many pieces was the floor? how did the floor pieces join together?
Old 09-21-2006
mikeronie is on a distinguished road
Don't mess with the boards. I took my 310 to a local shop and had them fit an air floor from a Mercury inflatable. Works good, the only draw back is it reduces the leg room. I also got an electric high pressure air pump for the floor. If you are in the So. Cal area let me know and I will loan you my boards to copy.
Mike
Old 09-21-2006
airfloor
what is the cost of an airfloor? I haven't found wone for the avon 310 for less than 550.00. how do you mean they "fitted" the airflooor? did they alter a floor, or just find one that would fit?
Old 09-23-2006
It cost me $500. I think they had to move a valve in the keel.
Mike
Old 09-30-2006
Saw that someone made a floor for a rubber dinghy with mattress support slats from IKEA in a recent magazine.
Installing Avon tow rings robmccarthy Gear & Maintenance 2 01-21-2003 06:05 AM
Avon hypalon lifespan grumol Gear & Maintenance 1 11-21-2002 10:04 AM
Avon high pressure floor mikemosabe Gear & Maintenance 5 08-17-2002 03:44 AM
Catalina 310 greatwhiteway Boat Review and Purchase Forum 10 07-02-2002 06:42 AM
Beneteau First 310 a95993 Boat Review and Purchase Forum 1 02-27-2002 03:37 PM
