Old 09-19-2006
rock33 is on a distinguished road
Cool Scorpian Project
I am new to sailing and I have an old Scorpian sailboat which is similar to a Sunfish. It needs patching on botton side and in cockpit floor. Does anyone know of a way to separate the top from the botton hull? There are rivits that connect a band that goes around the whole boat.My question is.....does this boat come apart to work on it or do I see a trip to the land fill in my future?
Thank you rock33
Old 09-19-2006
can't re member
yotphix is on a distinguished road
Don't know the Scorpian but I do know the sunfish. Regardless, if it went together it comes apart. Even if you need to glass it together again. Have no fear! Just drill out the rivets and see what happens!
Old 09-19-2006
Thank you I may have to go for it!!
Old 09-20-2006
jmunson2's Avatar
jmunson2 is on a distinguished road
I'll add my two cents...taken with a big ole grain of salt!
I also had a sunfish, although I never took it apart...love that boat! I liked the Sailfish better though - it was a bit larger and correspondingly faster!
First, I should think you could do all the repairs without seperating the hull/deck (not seeing it, I have no idea though).
Second, from reading, very light experience, and model building experience, the hull and the deck should be joined as they're usually two pieces - probably where the band is. The band may be just a pretty cover. If it is joined and that's the seam, you may need some sort of saw/grinding wheel to seperate the joint. In other words, you'll probably have to cut it apart.
If you do cut it apart, I would strongly suggest you mark the hull and deck first so that when you join it again you have some reference marks for alignment. You'll probably also need to sand it smooth, etc., to make sure the joint fits properly and won't leak once re-joined.
Hopefully I haven't wasted some cyber space with irrelevant nonsense.
Good Luck!
/s/ Jon C. Munson II
Old 09-20-2006
Thank you for the advice marking the hull and top to keep it lined up is a good idea..
Old 09-21-2006
I'd also recommend documenting the whole disassembly process with a digital camera. Having clear photos makes putting it back together much simpler and can answer a lot of the questions you'll have when you're doing it.
Old 09-23-2006
Thank you Sailingdog.. I think I'll be patching from the outside.. I found out that it is a one peice hull and I don't want to saw it in half... I don't have that much skill.. So I will be looking for a fiberglass repair kit or something of the sort..
Old 09-23-2006
Ahh... in that case, you'll probably want to get the West Systems PDF files on doing fiberglass repairs. Also, Practical Boat Owner, a British magazine, and DIY Boat Magazine (??) both recently had articles on fiberglass repair techniques over the summer. Might want to grab a copy or look it up in your local library.
Old 09-23-2006
Thank you for the resources.. Practical Boat Owner That sounds like it would be the way to go..
Old 09-23-2006
The DIY magazine may have been BoatWorks...
Project Boats -- Where Do You Find Them? glenpoisson Boat Review and Purchase Forum 34 10-24-2003 08:50 PM
Reasonable price for a project? khryssee Gear & Maintenance 9 06-23-2003 01:19 PM
For School Project energizerbunny0 Racing 1 11-02-2001 03:34 PM
Free Project Boat auto Gear & Maintenance 1 10-11-2001 09:29 AM
Free Project Boat!! auto General Discussion (sailing related) 2 09-18-2001 03:05 PM
