09-23-2006
I see a few problems with that idea.
One, the tank will have to be fairly small to remain manageable in both size and weight.
Two, the connections to the head are far more prone to leaking sewage if you have the tank removable, as you'll be constantly disconnecting and re-attaching the two connections.
Three, the smell from the installation will probably be a lot worse than a proper fixed tank installation.
Four, do you really want to risk dropping the tank and having gallons of sewage splatter about the cabin and furnishings of the boat when you're trying to carry the tank out to empty it?
