Rocna Anchor - Page 11 - SailNet Community
 1Likes
post #101 of 116 Old 04-13-2008
1977 Morgan OI 30
Joesaila's Avatar
No windlass...its on the list. I believe the rope I have is 5/8 though. I am going to use the 'old' chain w new hardware and I'm adding a bow roller. Thanks for the info!
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Joesaila is offline
post #102 of 116 Old 04-14-2008
Cam-
I wasn't sure if he had a windlass or not, but did want to mention it since if he had one or was planning on upgrading to a windlass at some point, it would be better to have the rode that will fit it, rather than having to replace the rode.
sailingdog is offline
post #103 of 116 Old 04-05-2009
Back to just the Jon boat
therapy23's Avatar
If you're using 5/16" chain, I would recommend going with 9/16" or 5/8" rope, rather than 1/2" . Most windlasses for 5/16" chain require 9/16" or 5/8" rope. They're also a bit better matched in terms of strength.
Dog,
What size Rocna for a Gemini 105Mc?
Where is the best price today shipped to Florida?
There is a WM 25 miles or so from me.
Thanks
therapy23 is offline
post #104 of 116 Old 04-05-2009
I'd go with a Rocna 15 for your boat. If you have the same philosophy about ground tackle I do, you might upsize to the Rocna 20... though the 15 would probably hold your boat in most conditions. I have the Rocna 15 on my boat, and it is probably a bit overkill. Maine Sail uses one as the primary on his CS36T IIRC, and that boat is a bit longer and heavier than your Gemini, but you have a bit more windage than he does.
You don't need one shipped to Florida, as West Marine now carries Rocnas, and you can order from West Marine and pick it up at the store—which sure beats shipping it from the Pacific NorthWest, where the North American manufacturer of the Ronca anchors is located.
Originally Posted by therapy23 View Post
Dog,
Thanks
post #105 of 116 Old 04-05-2009
Anchorsmith
Craig Smith's Avatar
Arrow
Thanks
Refer Rocna sizing recommendations:
http://www.rocna.com/main.php?sectio...=sizing&page=0
I'd say that SD's comments above are on target.
An up-to-date list of American resellers is maintained here:
http://www.rocna.com/main.php?sectio...ge=0&region=na
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Craig Smith is offline
post #106 of 116 Old 04-05-2009
therapy23's Avatar
Thanks,
When I went to the Rocna site for my length and moving up one on the chart for a cat I ended up with a 25 and there was one more option (in blue) higher still.
post #107 of 116 Old 04-05-2009
therapy23's Avatar
Rocna Anchors - Sizing Recommendations
Rocna Anchors - Where to Buy
OOPS!
Read the chart wrong. Biggest listed - the 25 (55 lbs)
post #108 of 116 Old 04-05-2009
Anchorsmith
Arrow
Therapy, looking at the Rocna chart, a 34' monohull at 4 t is at the very low end of the range for the 15 (which is rated for a 36'er at 7 t), if that's where you are - one size up is the 20, and even the 15 at this point has a lot of overhead to allow for a cat. The 15 would be adequate for most usage; go with the 20 if you want to be super conservative, and if the rest of your gear is matched to it (or you're prepared to also upgrade it).
More on the Rocna sizing:
http://www.rocna.com/kb/Rocna_sizing_recommendations
Craig Smith
post #109 of 116 Old 04-05-2009
therapy23's Avatar
Rocna sizing recommendations (Rocna Knowledge Base)
The cat is a Gemini. 8600 lbs from the factory, so let's say 11k max.
I'll check the rest of the gear. The chain looks really thin looking. Advertised as HT but don't know the size.
I haven't closed on the boat yet.
post #110 of 116 Old 04-06-2009
Therapy—
I'd recommend going with 5/16" G43 chain, if the windlass gypsy can handle it. Good luck on the survey and seatrial.
West Coast of Florida Anchorages Seagypsywoman Cruising & Liveaboard Forum 4 04-06-2009 12:47 AM
Slipping at Anchor nauticalrich General Discussion (sailing related) 22 05-18-2006 01:14 PM
remote anchor alarm? grumol Gear & Maintenance 0 11-21-2002 08:51 AM
Anchors for anchor rollers Dana125 Gear & Maintenance 4 05-12-2002 09:37 AM
Emergency Anchor Setup Fran49829 Seamanship & Navigation 3 04-18-2002 09:48 AM
