Rocna Anchor - Page 2 - SailNet Community
 1Likes
post #11 of 116 Old 09-30-2006
If the hydro bubble depends on the bubble to set properly, and the bubble is damaged, doesn't that tend to suggest the anchor won't set properly then.
If the anchor doesn't require the bubble to set properly, then it is just a useless gimmick to try and sell more anchors and increases the cost of the anchor without increasing the effectiveness of the anchor.
Either it is a poorly designed anchor with a possible vulnerability—as I can see if the anchor gets retrieved in rough conditions and rocky/coral terrain, the bubble could be damaged—or it is an anchor with an unnecessary marketing gimmick and somewhat questionable ethics and engineering. In either case, I wouldn't want that type of company making something that I am depending on to keep me, my crew, and my boat safe.
sailingdog is offline
post #12 of 116 Old 10-02-2006
purveyor of mischief
sanctuarysam's Avatar
Craig,
thanks for posting the article. i found it helpful, even if some of the information was inaccurate (such as the pricing for your anchors).
now..how soon might we see a distributor in the US? i suspect the freight is almost as much as the anchor were i to order from nz or canada.
now on a related topic..is there a formula for determing desirable length of chain:rope.
it appears Rocna is the way to go..
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
sanctuarysam is offline
post #13 of 116 Old 10-02-2006
The freight on mine wasn't too bad... I don't know how large an anchor you're looking at. I have 30' of 5/16" G4-high-test chain on mine, and can anchor in many locations with just a bit of rope in the water, but my boat draws considerably less water than many others...being a multihull.
One rule for chain in a combination rode is that you should have about 1' of chain for every pound of anchor weight... that's roughly how I did mine...works well enough.
post #14 of 116 Old 10-02-2006
if i'm reading the rocna website correctly..i need a either a 10 or 15kg model for my 30' 9400lb boat. if this thing holds as wonderfully as all the hype and glowing recommendations, then i could probaly get away with the smaller of the two..at what point is bigger always better, especially if my 5'5" spouse is trying to wrestle this thing from the briny deep.
now..here is the ridiculous aspect of my my question..what exactly does the chain do for you..
Sam
post #15 of 116 Old 10-02-2006
Craig,
"Some clown on another board stated that this negative factor must get worse with increasing depth, as the floatation would increase, rendering the anchor useless in deep water - now that's not right folks..."
I KNOW this guy! Met him in a bar once. He's the same fellow that claimed building bridges higher was a waste of money, because it would be far cheaper just to dredge beneath the bridges to increase clearance :-))
Bill
btrayfors is offline
post #16 of 116 Old 10-02-2006
Sam-
I'd go with the 15kg Rocna, rather than the 10kg. It will give you much more piece of mind, when you're anchored out and a gale or summer thunderstorm pops up with 50+ mph winds.
I'd also recommend that you get a windlass installed, even if it is a manual windlass. Makes retrieval much easier on you and the boat. If not a windlass, then at least a good chain pawl. I am installing a Simpson Lawrence/Lewmar Anchorman manual windlass for that very reason.
Bill- Unfortunately, it was some whack job on this forum that said that...
post #17 of 116 Old 10-02-2006
Anchorsmith
Craig Smith's Avatar
Arrow
Originally Posted by sanctuarysam
Craig,
Hi Sam - US distributor in the works, ask us for an update after the Annapolis show. But these things do take time.
Chain : rope - once you consider all the factors, you come away with the conclusion that 100% chain is "ideal" and chain the length of the boat is the absolute bare minimum. And you can compromise between those two extremes in any fashion you desire, according to the type of boating you do.
The advantages of chain to consider are:
  • Durable on the seabed, rocks, coral, other boats
  • Durable on your boat (no chafe)
  • Provides catenary to keep the pull on the anchor at a lower angle (this factor becomes more important the deeper the water)
  • Provides a certain amount of mass which equates to inertia, which helps prevent your boat "sailing" on the anchor
But of course it's heavy and doesn't absorb shock, so when choosing how much to carry, you can reduce the amount as much as possible until you don't want to "hurt" those advantages anymore, and make up the rest with rope. Make sense?
Re sizing: our recommendations are quite conservative, they're sort of based on Peter's attitude, which is formed from sailing around the world and visiting Antarctica and that sort of thing. It's a case of "don't oversize - we already did that for you". As you say the 10 would probably be adequate for your boat, but consider that the boat may be heavier than the 9400lb displacement you mentioned - when is the last time you weighed it? If it is likely to be much over, you are in the domain of the 15.
BTW, anchors up to 15Kg / 33lbs we can ship anywhere in the world by regular airmail. Which is fairly economical and gets it to your door, none of this importing-by-freight lark which is required for the bigger ones. It's still not cheap - but not a deal breaker.
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Craig Smith is offline
post #18 of 116 Old 10-02-2006
craig,
thanks so much for taking the time to provide the article and providing ground tackle '101' for me.
good point about weight..i suspect when you add the 50 gallons of water, 20 gallons of diesel and a 30 gallon holding tank...(and if my memory serves correctly, a gallon of water is over 8 lbs..hmmm), it all adds up quickly, not to mention 2 adults, electronics,etc.
so a 15 kg anchor it is. i'll check back after annapolis boat show.
thanks..
Sam
post #19 of 116 Old 08-12-2007
1977 Morgan OI 30
Joesaila's Avatar
We did our 'first' cruise out of Hingham, Ma., around the Cape to Nantucket, M.V. and back via Woods Hole thru the canal [watch out for Easterly winds on the outgoing tide, whew!] Overnighted off Clarks Is. [learned not to anchor in less than 20'. The tide was 10' at past high mark and 3.4' at a 25 degree tilt at 4 AM!] My 35 CQR worked well but I am going to get the Rocna 15 as soon as its locally available. I like what I read about it and want the safety of a good anchor for my family. [as you all do too]
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Joesaila is offline
post #20 of 116 Old 08-12-2007
halekai posted...
Last season my boat sustained considerable damage because a boat broke free in a wind storm and draged onto my boat due to poor mooring maintenance. I'm sure this clown has similar anchoring manners. Fortunately the damage was cosmetic only but the whole event set me back some serious pocket change with a 2% deductable
Thread drift...did you try to collect the out of pocket costs? If he dragged & you didn't, it should be a clear case of his neglegence.
xort is offline
West Coast of Florida Anchorages Seagypsywoman Cruising & Liveaboard Forum 4 04-06-2009 01:47 AM
Slipping at Anchor nauticalrich General Discussion (sailing related) 22 05-18-2006 02:14 PM
remote anchor alarm? grumol Gear & Maintenance 0 11-21-2002 09:51 AM
Anchors for anchor rollers Dana125 Gear & Maintenance 4 05-12-2002 10:37 AM
Emergency Anchor Setup Fran49829 Seamanship & Navigation 3 04-18-2002 10:48 AM
