Old 09-24-2006
nu2c is on a distinguished road
mast step pivot, tabernacle bolt etc.
Any ideas or advice about installing a mast raising sytem (mast step pivot, tabernacle bolt etc) to my San Juan 24?
Old 09-25-2006
Sails Call
pelicanl is on a distinguished road
self mast stepping
If you have slotted rail around the perimeter of your deck - or - a life line system on your boat, you can use the same proceedure I use on my Columbia 26. Do you intend to step it on the trailer or in the water? My boat came with a system to step it on the water, but I modified it to work while on the trailer. I haven't seen pics posted in this forum, so I will probably have to email them to you. My email is pelicanl@yahoo.com if you want to make the connection.
pelicanl
Old 09-25-2006
sidiag's Avatar
Grampian 26 Owner
sidiag is on a distinguished road
You might take a look at the Alberg 30 site. There is a nice
description of an A-frame that is used to raise/lower masts
on A30's.
link -> http://www.alberg30.org/maintenance/...nsteppingMast/
I down-scaled it slightly and use it on my AMI 7.0. and I am going
to build another to use on my Gramp 26.
The part that I really like is that the center (of mast) lift-point provides
very good controll of the entire process.
Regards,
Stan G.
s/v Tryphena a '74 Grampian 26
Old 09-25-2006
seeker
feetup is on a distinguished road
Mast step pivot, etc.
Take a look at Bob Schimmel's San Juan 23 website. There are a lot of tech tips re. the mast, running internal halyards, stepping the mast with different approaches. The 23 is very similar to your 24 and there are a few different approches to the problem. Lots of other good tips that would cross over directly to your 24.
Tim
Old 09-25-2006
knothead's Avatar
The "Sailor's Sketchbook" by Bruce Bingham has step by step instructions.
Old 09-25-2006
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Are you trying to step your mast in water or on the trailer? How many people are available to step the mast.
Old 09-30-2006
An easy way to do it is to use two pipes that are setup as an A-frame via two stanchion bases on the deck. Run the main halyard to the top of the A-frame and use a block and tackle from the top of the A-frame to the headstay chainplate to pull the mast upright. This was the rig used by my friends on their Cape Dory 25...should work on most boats.
This system works with just two people and can be used on either the water or the hard.
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Cabin Step Mast JNBDeVore Gear & Maintenance 6 10-03-2007 12:35 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
