10-01-2006
Sure, you could set up lines to the other two tanks from the RO water thank with check valves, to prevent water from flowing back into the RO water tank. Or you could use a vented loop to prevent water from flowing back into the RO tank. The check valve takes up less room though.
Probably the best setup would be a single line out from the RO water tank with a check valve, to a pump, that goes to a three-way diverter valve. That way you can go to either tank from the RO water tank, but the water won't go from either secondary tank to the RO water tank.
The diverter valve would have position one be RO->Tank1, position two be RO->Tank2, and position three be Tank1<->Tank2. That way no water can get back even if the check valve fails.
Hope that helps.
