Old 09-27-2006
mat0jab is on a distinguished road
Question Boom and Mast Attachments
When adding hardware to an existing boom or mast, should you use screws or pop rivits ? Also, should I be concerned about using stainless on a alum. mast or boom. The current project is re rigging my Lazy Jacks which were not even close to being installed correctly.
Thanks in advance, Mark
Old 09-30-2006
If you aren't going to need to remove the hardware, I would use stainless steel pop rivets, but I would coat them with Lanocote to help prevent any galvanic corrosion with the aluminum. I just used 3/16" stainless steel pop rivets to attach padeyes to the spreaders for flag halyards and a radar reflector halyard.
Be aware that most hand-powered pop rivet tools aren't designed to handle stainless steel pop rivets. The only hand rivet tool that I've found that says it is designed to handle 3/16" stainless steel pop rivets is one that I got at Sears, that is made by Craftsman.
If you have to use screws, use the coarsest thread possible, as finer threads tend to corrode more easily than coarser threads IIRC. Also recommend that you use lanocote or some other anti-corrosion coating on the screws.
Old 05-07-2007
aspiring sailor
fiestaMojo is on a distinguished road
What is the best (and/or simplest) way to rig a flag halyard for small decorative flags?
Old 05-07-2007
Umm... pop riveting a padeye to the spreader and then attaching a small block and running line through it to a clamp-on cleat on one of the shrouds takes about 20 minutes to do, plus whatever time it takes you to go up the mast.
Mast Painting KenD Gear & Maintenance 18 02-21-2009 09:15 PM
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 08:30 AM
mast raising and lowering divicolouis Gear & Maintenance 5 08-08-2003 10:08 PM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 04:10 PM
Can someone tell me how to unstep an O''Day 25? ejgubbins Gear & Maintenance 3 02-03-2002 12:45 AM
