10-02-2006
Yes, but to actually pot the installation properly, you should remove the core from the edges of the hole, and then fill the gap left behind with thickened epoxy. You should also drill the holes for the fasteners oversized, fill them with thickened epoxy and then re-drill the fastener holes the right size, after the epoxy has cured.
As Camaraderie has said, if it is just glass laminate, and no core...don't bother. Most modern boats have cored decks and topsides though...
