Old 10-06-2006
kennya's Avatar
kennya is on a distinguished road
best replacement fluid for a compass
What is the best replacement fluid for a compass? I have a Richie compass that has a large bubble. I would like to replace all the fluid, but do not have the foggiest as to what to use, oil or alcohol. I sent a quote request to Andrews Compass Service about six weeks ago but no response. Should I not worry with this one and just replace the compass or is repairing this one the better option?
Old 10-06-2006
Zanshin's Avatar
Zanshin is on a distinguished road
They used to be called "whiskey compass" but I don't think the color is right I would recommend using denatured mineral spirits, but that might depend upon your model - what compass do you have (manufacturer/model)?
Old 10-06-2006
kennya's Avatar
It’s a Richie pedestal mount from 1980 don’t have the model number on me.
Old 10-06-2006
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
You should only use mineral oil to replace compass fluid.
True Blue . . .
sold the Nauticat
Old 10-06-2006
sailingwife is on a distinguished road
Our boat we just purchased is also missing some fluid. The surveyor said to get it serviced but heck if I can find somewhere and it seems that one could do it themselves. Ours is a pedestal mounted Danforth and on the to do list is to try and remove it to see how it gets filled. I had thought they were filled with glycerin?
Old 10-06-2006
jgeissinger is on a distinguished road
Compass fluid
Mineral oil is indeed what is in compasses, and a readily available source for same is your local drug store. Baby Oil is pure, clean mineral oil, and it smells good too.
Old 10-06-2006
Zanshin's Avatar
Oops, my mistake. The small aircraft compasses need to move around a bit more and thus the mineral spirits; I wasn't paying attention and should have stated "oil".
Old 10-06-2006
hellosailor's Avatar
Check with the maker. SOME compasses use alcohol, others use mineral oil, still others use "compass fluid" which is similar to but not the same as mineral oil. Using the wrong fluid can change the damping AND dissolve the printing on the card, or cause the seals to leak again.
I think Ritchie used to have a special exchange program, swapping your compass for a rebuilt one at 1/2 of list price. It's worth asking them.
And if they'll sell you "compass fluid" that's meant for your compass...that's what I'd use, just to be safe.
Baby oil smells good because it has fragrance added to it. If you use mineral oil--use the plain pharmacy grade kind. Fragrance just can't do any good inside the compass.
Old 10-06-2006
camaraderie's Avatar
moderate?
If there is any evidence of leakage around the compass, you may need a diaphragm replacement and not just fluid...in which case that 1/2 price exchange deal might look tempting. I recently had my C.Plath innards replaced and it was about $300 but worth it due to the value of the compass.
Old 10-06-2006
capbill
capbillh is on a distinguished road
I had been told $150 to rebuild a Gemini 5" compass with new fluid & dome so I bought a new Richie for $115.
Fwd: Cruising Compass #10- the Newsletter for Sailors and Cruisers NewsReader Mass Bay Sailors 0 09-28-2006 10:15 PM
Cruising Compass #9- the Newsletter for Sailors and Cruisers NewsReader Mass Bay Sailors 0 09-21-2006 07:15 PM
Transmission & Autopilot Fluid aphil138 Gear & Maintenance 0 07-24-2003 02:13 PM
Compass for Zuma Zuma03 Gear & Maintenance 1 07-11-2003 12:26 PM
Dry Compass! cmj Gear & Maintenance 2 09-30-2001 09:15 AM
