Old 10-19-2006
chuck711 is on a distinguished road
Troubleshooting Norcold works AC volts not DC volts
Need Manual....Troubleshooting Norcold SCQT-6406 works AC volts not DC volts ?
When hooked up to shore power my Norcold works fine However on the batteries which are topped off nothing............
Any thoughts or suggestions?............
No manual on this unit ........where could I get one?
Old 10-19-2006
ebs001's Avatar
ebs001 is on a distinguished road
I suggest going to Norcold's website and calling there customer service department.
Old 10-19-2006
FrankLanger is on a distinguished road
We also have a Norcold refrigerator on our boat. I am not very familiar with the wiring set-up as we just bought the boat this year. However, the refrigerator unit itself seems fairly simple as far as operation goes--only an on/off switch in the upper inside corner (very hard to see without getting a kink in your neck!) which lights up green when on, and a temperature dial to adjust temperature.
However, before it will work, I need to turn on the refrigerator switch on a separate DC panel, and turn several switches on at a separate DC panel as well. So, could it be that you are missing a step in the way your boat's electronics are set up, outside of the refrigerator unit?
Just a long-shot thought....
Frank.
Old 10-20-2006
bsfree's Avatar
bsfree is on a distinguished road
The Norcold has an inverter that is wired to the dc system. It kicks in automatically whenever ac power is shut off. You might want to check your unit is wired to the dc, if it is, then check there is juice where it connects to the fridge, if there is then you might suspect the inverter itself.
Good luck
