Old 10-26-2006
johnr
jr438234606 is on a distinguished road
What sticks to teak?
The bulwark/toerail (forgive me if my terminology is wrong) is made of teak. It is bolted atop the hull-deck joint. The gel-coat on the deck butts up to this teak and goes slightly up it about 1/2 inch. My problem is that over time, where the teak and deck meet, small cracks have formed and water is ingressing somehow. I assume the cracks have formed due to the flexing of the teak.
I would like to seal these cracks along the entire length of the boat using something very strong yet flexible-- like 3M 5200. I know that 5200 will bond to epoxy, paint, and other materials very well, but I also need it to bond to the teak. Hence, my question. Will 5200 bond to unfinished teak? Would I need to maybe put epoxy on the teak first, then put the 5200 over that? I have found that 5200 DOES NOT adhere well to Cetol! Will epoxy stick to teak?
Old 10-26-2006
seeker
feetup is on a distinguished road
Sticking to teak
I know that if you use Sikaflex and coat the teak and gelcoat with Sikaflex primer you will have as adhesion as good as possible. I would be willing to bet that 3M has a primer for 5200 as well. Just be sure that the teak is freshly scraped and de-waxed just befor priming.
Old 10-26-2006
redcorvette1995 is on a distinguished road
5200 will bond to teak.
I installed a dozen teak strips with it on Monday evening.
Wipe down the teak to be boneded with lots of acetone.
Let it sit for a bit then apply 5200 to both the teak and the surface being boned too. Works perfectly.
I recommend the fast cure version.
You will need a way to keep the teak in place until the 5200 hardens
Teak vs fiberglass sole? jswwrites Gear & Maintenance 9 09-30-2006 04:15 PM
Teak or no teak... Keyne Boat Review and Purchase Forum 20 08-10-2006 06:08 PM
stain teak rails mroskothen Gear & Maintenance 3 07-26-2003 05:15 PM
Teak deck Q ekhar Gear & Maintenance 8 03-10-2002 05:48 PM
3M 5200 & Teak Cleaners mikehoyt Gear & Maintenance 1 11-22-2001 04:57 PM
