Tartan 37 cutlass bearing - SailNet Community
 1Likes
  • 1 Post By glymroff
post #1 of 4 Old 03-04-2016 Thread Starter
Irunbird's Avatar
I've looked around for a while trying to find the right cutlass bearing for our new-to-us boat, but struggling a bit. She's currently in the water and about to get hauled for some work and one chore on the list is replacing the sleeve bearing. The Duramax website only has sizes listed in the different materials, but no boat model tables or anything like that. Do I need to remove it first, make the measurements, then order?
Ray
Irunbird is offline
post #2 of 4 Old 03-04-2016
T37Chef's Avatar
Re: Tartan 37 cutlass bearing
I will look for you in my records, i didn't buy, my mechanic did.
Shawn
T37Chef is offline
post #3 of 4 Old 03-05-2016
glymroff's Avatar
Location: Winter/Spring - Sailing, Summer/Fall - Vermont
We just did ours last month... prop guy accidentally broke our shaft (wasn't funny), but he replaced shaft, cleaned up flex coupler, (for free), and I replaced the cutlass Figured what the hell nows as good a time as any. I can't remember the size, but I do remember that the small marine hardware store had it in stock. That would imply it's a common size. I would just wait and measure/ask the yard guy when you haul. If your in the states I bet a local shop has it. IIRC I paid about $80 bucks for it.
Good Luck.
glymroff is offline
post #4 of 4 Old 03-05-2016
glymroff's Avatar
Found the receipt... $82.95, 1 x 1-1/2 x 4 Our boat is '77 T37 #027. Yours might be different.
Hope that helps.
T37Chef likes this.
glymroff is offline
Cutlass Bearing and rudder bearing smillinjack Gear & Maintenance 3 07-11-2010 09:18 PM
PS 37 Cutlass Bearing waypt1 Pacific Seacraft 5 01-15-2008 04:03 PM
Tartan 30 cutlass bearing moxnix Gear & Maintenance 4 09-07-2006 11:26 PM
Cutlass bearing alpeaks Gear & Maintenance 2 05-17-2004 02:10 AM
Cutlass bearing lgsailor52 Gear & Maintenance 5 07-04-2002 07:25 AM
