Need help with wiring boat. - SailNet Community
post #1 of 16 Old 03-04-2016 Thread Starter
My new to me Potter 19 came with a rat's nest for wiring. I am starting over to make it right. So far I have purchased a 5 way switch panel and cut out the area to make it fit. The boat had a fairly nice setup for a P19 that is with two batteries and a batt switch. Previously the boat had a 4 stroke outboard with alternator so there are big cables coming from that to the batt switch. All wires leading from the alternator, and both batteries to the batt switch are beaffy 4 or 6 gauge wires appropriate for a bigger boat. Leading away from the battery switch to the boat's DC switch panel was a 12 or 14 gauge wire. Nowhere along the way are any fuses.
My list of equipment onboard is:
  • 3 LED interior lights
  • LED Nav Lights
  • Masthead Steaming/Anchor 2 bulb LED combo.
  • 3- 12 V "cigarette lighter" plugs
Possible future additions:
  • Fixed VHF radio
  • Tiller Autopilot.
The DC panel is on the right side of the boat and the Battery Switch is on the Left, I figure a 10-12 foot run. I am heading to the boat today to remove the rat's nest and will know the distance later.
Would a 10 gauge wire work with a 30A inline fuse work? If not:
What size wire should I have leaving the battery switch to the DC panel to handle this load?
How do I add a Fuse to this line?
How do I step down from a big fat wire to the 12 or 14 gauge on my DC panel?
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #2 of 16 Old 03-04-2016
Re: Need help with wiring boat.
I can't say I'm very keen on those uninsulated P clips. I though they were for piping? Eventually they might cut through the insulation, then you'll have live P clips. Wait a minute, it gets better! There's a P clip on the plus and negative wires, both fixed to the same metal stud! So that's where the fire will start.
My preferred method is these :
https://hermanproav.com/product/4797...wqrRoChbLw_wcB
If you need to change something, just cut the cable tie, install another. The mount stays put. Cool.
Also it looks like there are two wires going into one crimp. Better to install a ring crimp on both wires, and have two ring terminals on the stud.
MarkSF is offline
post #3 of 16 Old 03-04-2016 Thread Starter
Where to put it all.
The wiring and panel is right above where the porta-potti belongs on this boat. I could install the wire distribution right beneath the DC switch panel but do not want all the wires and distribution blocks exposed to the flammable gas in the area..
Actually I think it would just look cleaner and easier if I moved the two distribution blocks forward a bit. Just forward of this area is one of the batteries so the jumper to the negative bus would be kept short and cleaner. I would need to add 3-4 foot jumpers to bring the power from the switch panel to the terminal block.
Here are the two blocks I have for distributing Negative and Power from the DC switch panel.
Below are pictures of the two areas. Area 1 is just below the switch panel in the Porta-potti cabinet area 2 is forward of this, next to the battery. I have some star board i would build up a 1/2 panel and epoxy it to the hull just under the hull liner to mount the two distribution blocks. This would keep most of the wiring and the distribution out of sight and no chance of it being bumped. All feedback appreciated.
Location #1
Location #2
Jordan
Oceanside CA
jephotog is offline
post #4 of 16 Old 03-04-2016 Thread Starter
Originally Posted by MarkSF View Post
Thanks Mark,
I have a bunch of those type of Cable mounts left over from my previous boat. I like them for the same reasons. I plan on using thickened epoxy to mount them throughout the boat where wires will be running. Overall it will be a very simple layout, but I want to do it right.
Another red flag is the wire you are talking about makes a 180 bend at the ring. The positive and negative you see coming from the top are from the aft part of the boat coming from the boat alternator. There was a 4 outboard on there but it was stollen and the wires cut short before I purchased the boat. I am not sure the wires are still long enough to reach an outboard but I can either move these wires and coil them out of the way for a future alternator or Solar panel or remove it and use it to make the run from the battery switch to the DC switch panel.
Jordan
Oceanside CA
jephotog is offline
post #5 of 16 Old 03-04-2016
Learning the HARD way...
eherlihy's Avatar
Originally Posted by jephotog View Post
... Leading away from the battery switch to the boat's DC switch panel was a 12 or 14 gauge wire. Nowhere along the way are any fuses.
  • LED Nav Lights
  • Fixed VHF radio
  • Tiller Autopilot.
Do not use an inline 30A fuse.
Use an MRBF on the batteries. Use an appropriately sized wire to run from the batteries to the battery switch, and then from the common lead to the bus on the breaker panel.
Your projected total load is less than 15A, so you need to size the wire to the breaker panel accommodate 15A (or whatever your likely amperage is) for a less than 3% drop for the length of the wire from the battery through the switch, to the panel. On a Potter 19, I would guess this to be less than 30 feet. AWG #8 will accommodate this.
Then use an appropriately sized breaker and wire to run to each individual circuit.
BTW- I agree about the metal P-clips. They should at least be insulated.
eherlihy is online now
post #6 of 16 Old 03-04-2016
eherlihy's Avatar
MRBF:
Block - attaches directly to battery terminal:
post #7 of 16 Old 03-07-2016
RichH's Avatar
Here's a wiring calculator for sizing the correct wire gage based on amps and distance the wiring run; also good for fuse & circuit breaker sizing: Circuit Wizard - Blue Sea Systems
Note: youll have to click on the legal/risk acceptance clause (I agree, etc.) before the calculator is enabled and active.
RichH is offline
post #8 of 16 Old 03-07-2016
BTW, if you're looking to calculate voltage drops, here is a handy calculator :
Voltage Drop Calculator Genuinedealz.com
It's also a very good supplier of marine electrical supplies. I particularly like their custom cable service, where they add the crimps etc. for you. I got them to make a bunch of new heavy-gauge battery cables, and the quality is really good.
If I put into the calculator a 12 foot run, and 15 amps of current, you need 8 gauge or thicker to stay under a 3% voltage drop. At 30 amps you need 6 gauge.
MarkSF is offline
post #9 of 16 Old 03-10-2016 Thread Starter
So for now I have decided to skip the battery switch and go straight to the panel from the one battery I have to install for now. I stole the battery cable coming from the back of the boat where the alternator on the 4 stroke used to be (boat no longer has a 4 stroke). I went down to the chandlery where they had all the tools I need to alter this cable and make one more to fit my planned layout. Photos to follow.
Note: when I took off this battery cable it was the one that everyone was concerned about with the uninsulated P-clip, there was not two wires in the one ring connector it just looked like it. However when I removed all the old wiring there was triple wires attached to ring connectors at the negative terminal on the battery to provide the negative all of the circuits. It was quite the mess on a very simple wiring system.
Now I have a question on fuses. This is for another boat my Ericson 32 which just had a battery charger failure and I found both batteries dead.
Should I even try to recharge a battery found completely dead or buy new batteries?
Initially I thought the MRBF fuse on each battery protected the system through the battery switch and to the dc switch panel. But realized if I have the battery switch on "BOTH" There is a potential for each battery to provide half of a amperage and exceed the capacity of a wire coming out of the battery switch. Should there also be a MRBF or another type of fuse on the output from this switch to protect that cable from getting too much amperage?
Jordan
Oceanside CA
jephotog is offline
post #10 of 16 Old 03-10-2016
Each power source (battery, alternator, shore power charger, etc.) should have a fuse located on the output, and fused at whichever is less: The size of the load it is connected to, ~110~120% of the maximum output of the device, or the ampacity of the wire. This last is based on the wire size and type and can be looked up online.
Forget the *switch*, you don't fuse power sources there. You fuse them at the source.
hellosailor is offline
Wiring my boat creelclmsn Electrical Systems 4 10-04-2014 12:09 AM
Introduction to wiring a boat? CatfishSoup Electrical Systems 13 01-19-2009 09:12 AM
old boat wiring KasbeKZ Gear & Maintenance 20 10-17-2008 01:35 PM
Wiring my boat for cable TV Perithead Gear & Maintenance 11 04-18-2008 01:34 PM
Wiring the boat - labeling Windborn Gear & Maintenance 15 03-11-2008 08:29 PM
