Halyards - SailNet Community
post #1 of 4 Old 03-18-2016 Thread Starter
Halyards
Ok so I have an Edel 540 with 20ft mast.Before the season starts I want to renew Main and Spinnaker Halyards. Checked on a site which did the length calc for both given as 48ft for Main and 59ft for Spin. So my question is, which may seem a dumb question to those of you, who have been around the sailing world for a while, if the mast is 20ft thats 40ft and the cleats are on the mast why do I need 59 ft for the Spinnaker seems a tad long, or am I missing something. Even the Main is a little long, but I can live with that.
Venturer2015 is offline
post #2 of 4 Old 03-18-2016
Sailor
Re: Halyards
Measure the old ones
It's better to sail in a boat and think about God than to sit in a church and think about sailing
Jim_W is offline
post #3 of 4 Old 03-18-2016
Re: Halyards
The indicated lengths are probably assuming lines run aft, plus some extra to be able to trim for wear and tear at the masthead when in use over time.
As mentioned above, simply use the originals as a guide.. attach a light messenger line, pull them out of the mast (leaving the messanger line there) and make new ones, then pull them back in with the messenger lines you left behind. Easy enough to make the new ones a bit long for the same reason, or in case you intend to lead lines aft to the cockpit at some point.
Faster is online now
post #4 of 4 Old 03-18-2016 Thread Starter
Re: Halyards
Thanks for the reponses and that's what was confusing because the given lengths from the calculator didn't match what's on the mast. As an electrician I am used to the old saying of 'better looking at it, than for it' but there's a limit.
Thanks again
and Faster you might also like A Ship is Dying by Brian Callison unless you`ve read already
New halyards for an S2 7.9 what to get SHNOOL Gear & Maintenance 6 02-11-2015 02:12 PM
rope & wire halyards vs all rope halyards kjango Gear & Maintenance 20 03-02-2013 02:16 PM
Replacing halyards Thorp Gear & Maintenance 17 11-08-2010 05:50 PM
Banging halyards wchevron Gear & Maintenance 17 06-11-2008 07:43 PM
Halyards sail-away Gear & Maintenance 2 06-11-2001 03:49 AM
