Old 11-01-2006
gconley is on a distinguished road
Transmission Heat Exchanger
Greetings,
I have just taken delivery of a Gulfstar Sailmaster 47. The boat was delivered by a professional captain arriving Newport RI on last Sunday evening (Oct 29/06). Yes the boat came through with reported 60 knot sustained winds and 30 ft seas. A testament to both the boat and captain.
Back to the problem, on routine inspection, the transmission (Borg Warner) was found to have seawater in it. The captain has suggested as has another experienced captain, that the heat exchanger for the transmission is optional. In order to get the boat to it's permanent winter berth in Boston, the heat exchanger was bypassed and the transmission flushed. It is running but I can't help but think this is problematic. I would appreciate any opinions this highly experienced forum can offer.
Thanks as always
gconley
sv Bacchus
Old 11-01-2006
soul searcher's Avatar
soul searcher is on a distinguished road
I have alot of expieriance with bigger gears on power boats. not much with bog warrner but if the manufacturer put a cooler on that gear then it probably needs to be there. a cooled gear will have a longer life. usually when a cooler goes the oil gets pumped out the exhaust with the water and the trans cooks itself. your lucky it was caught you probably got a pin hole leak. some times they can be repaired. zincs are critical in your cooler there are alot of differnt metals in one and they are usually the first thing to go if you have an electolysis problem. I'd fix it soon. thats just my two cent.
Old 11-01-2006
redcorvette1995 is on a distinguished road
Agreed the cooler is there for a reason.
It should be repaired or replaced.
The cooler temperatures at this time of year probably helped.
I think it would be a lot harder on the tranny come summer with higher air and water temps.
Old 11-02-2006
I'd have to third the motion to replace/repair the tranny cooler. Transmission coolers are usually there for a reason. On a boat, the confined space for the engine and transmission, and the lack of airflow, means that the transmission often builds up heat. In the summertime, especially in the tropics, you're going to have a problem.
Old 11-02-2006
Thank you all - that was my thought as well. I have to get the boat moved this weekend from Newport to Boston. I will sail her most of the way as possible so. Does anyone have an idea where I might find a heat exchanger?
Thanks
gconley
S.V. Bacchus
47 Gulfstar Sailmaster
Old 11-02-2006
camaraderie's Avatar
moderate?
Here's a link to coolers...have one of them. Good product good folks.
http://www.tadiesels.com/oil-coolers.html
Old 11-02-2006
pigslo's Avatar
pigslo is on a distinguished road
Also Diesel Parts Sales in Houston will send you one. Randall Cesar III helped me with my parts needs. Also, the Borg Warner velvet drive was designed for up to 300 h.p. so it is pretty tough. Long term I think I would return it to the original settup but in an emergency I would use it.
Old 11-05-2006
Dawkahab is on a distinguished road
On Borg Warner Gears, especially 70 series, 71-73 etc. Coolers are not optional, In fact a very experienced BW repair facility advised me many years ago. that the cooler should receive the first(coldest) raw water, before it goes to the engine heat exchanger. My experience has been that depending upon hourd they should be rebuilt every 3-4 years. Lots cheaper than replacing a failed one.
Heat exchanger cleanup and cleanout dargiem Gear & Maintenance 2 01-31-2003 04:52 PM
Leaky transmission Volvo Penta 2003 ekhar Gear & Maintenance 0 08-15-2002 05:54 PM
Velvet Transmission manual AndrewB Gear & Maintenance 0 08-22-2001 08:05 AM
heat exchanger gunk creek Gear & Maintenance 0 06-06-2001 06:55 PM
heat exchanger gunk creek Gear & Maintenance 0 06-06-2001 06:54 PM
