Whisker Pole? What are these? - SailNet Community
 3Likes
  • 1 Post By Faster
  • 1 Post By Lake Superior Sailor
  • 1 Post By RocketScience
post #1 of 7 Old 03-20-2016 Thread Starter
MacBlaze's Avatar
So what are these? I assume the previous owner had a whisker pole or something and used these to store it on the stanchions. There are two. But they look awful small and there is absolutely no indication that anything like a track or a ring was ever mounted on the mast. I know bupkis about whisker poles but don't they need to mount to the mast somehow?
And why would a Hunter with a 110% jib need one anyway?
Gaudeamus igitur iuvenes dum sumus...
before it's too late
MacBlaze is offline
post #2 of 7 Old 03-20-2016
Re: Whisker Pole? What are these?
They do look like whisker pole storage clips.. the whisker pole is used when sailing downwind to hold the clew of the jib outboard - otherwise the jib tends to collapse and fill and collapse and fill, esp once you're lower than a broad reach. Stabilizes the rig considerably.
There should be some kind of ring on the mast, but it's possible that the PO clipped one end to the shrouds, esp if the pole is on the short side. From the clips it looks like a pretty skinny pole.
Look on the bright side.. these would be a good place to stow your boathook.. at least until your dockings all go smoothly
Come to think of it.. maybe that is what they were for in the first place...
eherlihy likes this.
Faster is offline
post #3 of 7 Old 03-20-2016
Lake Superior Sailor's Avatar
Shore power cord?...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #4 of 7 Old 03-20-2016
RocketScience's Avatar
...Look on the bright side.. these would be a good place to stow your boathook...
...and that's exactly what they are.
United Yachting's Pole Holder
MacBlaze likes this.
Synthetic Rigged Wauquiez Pretorien 35
RocketScience is offline
The Following User Says Thank You to RocketScience For This Useful Post:
MacBlaze (03-20-2016)
post #5 of 7 Old 03-20-2016
flyingwelshman's Avatar
I sail a Hunter 30 with a 110 jib and use a whisker pole quite often.
If I have to sail DDW for any distance I'll rig the pole and set a preventer on my boom. It makes going wing and wing a lot easier and requires less constant attention on the helm.
As far as I know whisker poles - like spinnaker poles - are attached to a ring on the mast. My mast is an Isomat that is formed to kae a spinnaker car. There is no track per se but grooves on the leading edge of the spar. I bought an Isomat spinnaker car a couple of years ago. It wasn't that cheap so if I sell my boat I'll probably take it with me if it fits my new boat. Probably what the PO of your boat did.
1989 Hunter 30'
Southern Georgian Bay
Visualize the vastness of the oceans; the infinity of the heavens; the fickleness of the wind; the artistry of the craft and the frailty of the sailor. The oneness that may be achieved through the harmony of these things may lead one to enlightenment. - Flying Welshman
flyingwelshman is offline
post #6 of 7 Old 03-20-2016 Thread Starter
MacBlaze's Avatar
Ah-Ha! Awesome detectiving...
MacBlaze is offline
post #7 of 7 Old 03-20-2016
Thanks, but I'm not as awesome as you think. I actually have a set on my boat.
whisker pole or spinnaker pole ltgoshen General Discussion (sailing related) 11 06-20-2012 01:38 PM
Whisker Pole Aurea Cal 0 10-15-2010 11:14 PM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
Using a Whisker Pole Dan Dickison Racing Articles 0 09-04-2001 08:00 PM
