Propane stove repair CT/RI area - SailNet Community
 1Likes
post #1 of 17 Old 04-12-2016 Thread Starter
HANUMAN
RobGallagher's Avatar
Propane stove/oven repair in the CT/RI area.
Who would you trust to repair and test a propane stove?
Easy enough to take off the boat and bring to them.
Thanks.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #2 of 17 Old 04-12-2016
fallard's Avatar
Re: Propane stove repair CT/RI area
Rob: Have you checked with the local propane suppliers? I believe some suppliers do repairs.
fallard is offline
post #3 of 17 Old 04-13-2016
They are remarkably simple machines. What's wrong with it? ie.... door broken off or won't light? I suspect the later, but some here could probably help trouble shoot.
Jeanneau 54DS
Minnewaska is offline
post #4 of 17 Old 04-13-2016
TQA
Bombay Explorer 44
TQA's Avatar
If it is a Force 10 and you need to remove the burners then be prepared to have to drill out all retainers and tap oversize. Alternatively buy all new burners and retaining screws.
Ask me how I know this.
TQA is offline
post #5 of 17 Old 04-13-2016 Thread Starter
HANUMAN
I removed my EnerRoyal King stove today. I had been worried about a very, very, very slow, hard to detect propane leak. So I have been very careful to close the tank valve when done cooking. If I left the tank valve open and shut off the stove, over a period of an hour or so the pressure in the lines would start to drop.
One and the SCAREY bit it that the fitting for the oven valve to burner had backed out.
Two is there is a problem with the oven valve, it appears frozen.
Three is that it is probably a very good thing that the oven valve was frozen closed, but maybe this is the source of my leak.
Everything else works great.
It needs a good scrubbing so I'll take it apart and see what happens.
Google search has not come up with a manufacturers website. PARTS??????? Help. PARTS?
HANUMAN
'88 C&C 30 MKII
NOANK, CT
post #6 of 17 Old 04-13-2016 Thread Starter
HANUMAN
C&C, Metric bits... Screams Canadian made stove.
Any help from the Great White North Aye?
...with humble apologies about the whole Trump thing...
HANUMAN
'88 C&C 30 MKII
NOANK, CT
post #7 of 17 Old 04-13-2016
dinosdad's Avatar
Bring it home , scrub it up, rig up a hose from the grill( be creative) slather some soapy water around and check for leaks .
Next call south shore yachts , they know everything c&c and might have a line on who has a stash of stove parts. The valves and burners are most likely sourced from a outside source from the stove manufacturer and might cross reference to a another stove .
If you need someone to sit on your deck and watch the stove for leaks while emptying your liquor cabinet ... I'm in, willing to do my part.
1994 Catalina 320
Noank ct
dinosdad is offline
post #8 of 17 Old 04-13-2016
Yikes, that's a lot.
Unrelated to the stove, do you have a powered solenoid at the tank? Closing the tank valve is good practice, but if the solonoid is working properly, no defect at the stove should cause a leak.
As for the stove, do you think those issues are worth fixing, as opposed to going new?
Jeanneau 54DS
post #9 of 17 Old 04-14-2016 Thread Starter
HANUMAN
It's a thousand bucks for a new stove from Defender....YOU could do more damage than that from my bourbon collection. Thanks for the offer. Now go to bed, you have to work in the AM.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
post #10 of 17 Old 04-14-2016 Thread Starter
HANUMAN
Sticker shock on the price of a new stove, they are just silly. Just the oven valve is jammed up. Hopefully I'll be able to find new parts.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
Propane Stove Puzzle JimPendoley Gear & Maintenance 9 04-27-2015 11:14 PM
30 Year Old Propane Stove gbgreen59 Gear & Maintenance 26 01-08-2015 10:10 AM
Propane stove testing DulceSuerna Gear & Maintenance 12 01-01-2011 07:54 AM
propane stove bar1 Islander 1 09-11-2010 11:35 PM
propane stove QuickMick Gear & Maintenance 4 04-02-2010 01:36 PM
