Old 11-13-2006
Yawl73 is on a distinguished road
Wood Boat
I have a wood boat with a wet bilge. Boat was built in 1923 I just spent the best part of the summer re-caulking with oakum and pitch. All the out side has been filled and tamped lap strike and deck. Inside has been tarred over and drop keel board trunk was glassed over after a full replacement. Now I have about 3 to 4 inches of sea water in the bilge every morning. Shaft seals look good, rudder is outside with chain steering. Any thoughts?
Old 11-13-2006
Gene T's Avatar
Gene T is on a distinguished road
How long has it been in the water? If just launched it could leak until the lumber swells. If this is true you would have less water in the bilge each day. I would also think it would be easy to see where the water is coming in. If you can't tell then I would think it is in the bilge somewhere.
Old 11-16-2006
Doug_53 is on a distinguished road
What do you mean the prop shaft looks good ! How much does it drip ?
Jack Tar
Old 11-16-2006
Fareast is on a distinguished road
What about your thru-hulls? The valve itself or the fitting.
Old 11-16-2006
paulk's Avatar
paulk is on a distinguished road
Sometimes old-timers throw sawdust into the bilge in the hope that it will swell up when it gets wet and fill the gaps the caulkers missed. Water may be seeping in through fittings, as suggested above, or through fastenings, too. Re-caulking may even have increased leakage by forcing the boards further apart. Is the leaking worse while under way? Stopping up the limber holes in different sections of the bilge may help locate where the water is coming from. More details about the type of construction and the boat's design might help garner better advice.
The Joys and Pitfalls of Buying a New Boat - Part 1 Lin & Larry Pardey Buying a Boat Articles 6 10-24-2010 04:49 PM
New name (I know, I know) owlmtn Boat Review and Purchase Forum 13 12-13-2009 07:46 PM
Seakindly Boats vs.the rest rmf1643 Boat Review and Purchase Forum 12 09-02-2009 12:49 PM
Production blue water boats JakeLevi Boat Review and Purchase Forum 73 07-31-2009 10:07 PM
The Joys and Pitfalls of Buying a New Boat - Part 2 Lin & Larry Pardey Buying a Boat Articles 0 11-06-2006 04:51 PM
